Thanks you. I intend to use MSP430F1611,having SPI interface. The problem is from the suggestion of CC1000 from Chipcon I have to connect the SIMO and SOMI pin together. Since I have to connect more than one device on SPI so I cannot connect the SIMO and SOMI together.
How could I do. As I know for MSP430F1121 , u can interace to cc1000 with full software control , not SPI standard interface.
Hi Im also developing a system using a MSP430F and a Chipcon chip. Although I have got the system working in the fact that one unit transmits and the other recives I can not get each unit to switch. I.e the TX-RX and RX-TX switching does not work. Any ideas? Thanks
Here is the code for CC1000 interfaced with AVR microcontroller. I'm working in frequency 433MHz ISM band. I've tested the code for about 50m distance. You can equally changed to MSP430 based on this code.
MSP430+CC1100 seems to be the hottest solution no. we had just made more than 10k and a 100k order will be followed. It's a very small flex PCB with MSP430 and CC1100. I guess it's something waring on the wrist.
CC1100 is ok for most small scale applications.
However it would be some what difficult to understand. Unless you have their development board to try out.
I did the same on a Summitek http://www.summitek.com.tw/ make RF module "ST-TR1100+PA"
After tinkering for a while.....succeeded.
I am working on cc1070 with a MSP430F processor.
I need a help for code for the cc1070.
Evenif I found the code for cc1020 at TI website, I am a novice to the interface
programming. Please let me look at your code.
