prinsloo
Member level 5
- Joined
- Sep 19, 2004
- Messages
- 93
- Helped
- 2
- Reputation
- 4
- Reaction score
- 1
- Trophy points
- 1,288
- Location
- Bethlehem RSA
- Activity points
- 697
; setup and configuration
processor 16f84A
include <p16f84A.inc>
__config _XT_OSC & _WDT_OFF & _PWRTE_ON & _CP_OFF
; variables in PIC RAM
cblock 0x0d ; Start of block
count2 ; ISR counter
old_w ; Context saving
old_STATUS ; Idem
Delay1 ; Define two file registers for the
count1
endc
; ********** PROGRAM START **********
org 0 ; Program start at address 0
goto main
; INTERRUPT HANDLER
org 0x04
goto IntServ
; MAIN PROGRAM
main:
bsf STATUS,RP0 ; Select Bank1
bcf OPTION_REG,INTEDG ; Set interrupt on falling edge
; by clearing INTEDG bit of OPTION_REG
movlw b'00000001' ; PORTB bit 0
movwf TRISB ; is Input, all other bits are Output
bcf STATUS,RP0 ; Go back to Bank0
clrf PORTB ; Clear PORTB
;bsf PORTB,0 ; set PORTB bit 0
; SETUP INTERRUPTS
bcf INTCON,INTF ; Clear external interrupt flag (INTF = bit 1)
bsf INTCON,GIE ; Enable global interrupts (GIE = bit 7)
bsf INTCON,INTE ; Enable RB0 interrupt (INTE = bit 4)
; flash led
Loop:
nop
nop
nop
goto Loop
;clrf PORTB
; Interrupt Service Routine
IntServ: ; First test if source is an RB0 interrupt
btfss INTCON,INTF ; INTF flag is RB0 interrupt
goto notRB0 ; Go if not RB0 origin
; Save context
movwf old_w ; Save w register
swapf STATUS,w ; STATUS to w
movwf old_STATUS ; Save STATUS
; Make sure that interrupt occurred on the falling edge
; of the signal. If not, abort handler
btfsc PORTB,0 ; Is bit set?
goto exitISR ; Go if clear
; interrupt action
;clrf PORTB
movlw 10 ; Number of repetitions
movwf count2 ; To counter
wait: ; Check to see that port-B bit 0 is still 0
; If not, wait until it changes
goto exitISR ; Go if bit not 0
; At this point RB0 bit is clear
decfsz count2,f ; Count this iteration
goto wait ; Continue if not zero
; Interrupt action consists of toggling bit 2 of
; port-B to turn LED on and off
; ACTION!!!!
movlw b'10000000' ; Xoring with a 1-bit produces
xorwf PORTB,1 ; Complement bit 2, port-B
; exit ISR
exitISR: ; Restore context
swapf old_STATUS,w ; Saved STATUS to w
swapf old_w,f ; Swap file register in itself
swapf old_w,w ; re-swap back to w
notRB0: ; Reset,interrupt
bcf INTCON,INTF ; Clear INTCON bit 1
retfie
delay:
movlw 4
movwf count1 ; Store value in counter
repeat:
decfsz count1,f ; Decrement counter
goto repeat ; Continue if not 0
return
end
