dpaul
Advanced Member level 5
- Joined
- Jan 16, 2008
- Messages
- 1,856
- Helped
- 317
- Reputation
- 635
- Reaction score
- 352
- Trophy points
- 1,373
- Location
- Germany
- Activity points
- 13,445
Hi all,
I am trying to simulate a uP core defined in sv using Xilinx Vivado suite.
However I get an error message for which I cannot find a fault.
This error message points to the part of the code as below:
Note that in the above error line, the variable 'dmem_rd_check_size' is allocated to type 'type_operation_mode_e'.
I have the 'type_operation_mode_e' defined in an `include file as follows:
I have checked this entire file/code and no where is there an illegal assignment for 'dmem_rd_check_size'.
Then why is the Vivado simulator throwing such an error?
I have hit a wall. Please help or advice.
Error: "[VRFC 10-301] an enum variable may only be assigned to same enum typed variable or one of its values"
`ifdef MPU_EN
output logic [ ARCHITECTURE_BASE-1:0] dmem_rd_check_addr,
output type_operation_mode_e dmem_rd_check_size, <-- ERROR line
`endif
typedef enum logic [1:0] {
DATA_MODE_BYTE,
DATA_MODE_WORD,
DATA_MODE_DWORD,
DATA_MODE_X=2'bxx
} type_operation_mode_e;
