[Moved] what is Intelligent Devices ?thanks
okman
Member level 1
i need explain in details on the power switch device (Intelligent switch Devices )
like characteristic, mechanism , application and datasheet:?::?:
thanks
Re: what is Intelligent Devices ?thanks
Please explain with more detail. What You consider under inteligent switch devices?
Intelligent switch device is a wide meaning sentence. Please be specific and more elaborant on your question for proper replies.
ok,
I mean intelligent device is intelligent power transistor or thyristor or power diode
the intelligent device is protect itself from high di/dt or dv/dt
but i dont find the explaining of it in details
please help me thanks
You should search as Solid State Relay, but power diode is not switch, and there is nothing inteligent in this devices.
For AC use triac not thyristor in solid state relays.
Go on google and type solid state relay circuit (search as image)
or
search edaboard
