kushal nandanwar
Full Member level 3
// comp2s128b
module comp2s16b(s,a,clk);
input [15:0]a;
input clk;
output reg[15:0]s;
always@(posedge clk)
begin
s=~(a)+1'b1;
end
endmodule
// comp2s128b
input [15:0]a;
input clk;
output reg[15:0]s;
begin
s=~(a)+1'b1;
end
endmodule
Yes, it's good practice to use non-blocking "<=" assignments in edge sensitive always blocks. But it's not strictly required. In the present example, it makes no difference at all, because the assigned value isn't read in another expression.I think inside the always@ clocked process statement you need to use the "<=" operator instead of "=" operator
Is the simulator showing any error or warnings ?
What is the given inputs and expected output ?
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 `timescale 1ns / 1ps ////////////////////////////////////////////////////////////////////////////////// // Company: // Engineer: // // Create Date: 19:43:04 01/29/2016 // Design Name: // Module Name: MAF // Project Name: // Target Devices: // Tool versions: // Description: // // Dependencies: // // Revision: // Revision 0.01 - File Created // Additional Comments: // ////////////////////////////////////////////////////////////////////////////////// module adaptive_filter8(yn, xn, dn, mew, clk); output [15:0]yn; input [7:0]xn; input [15:0]dn; input [7:0]mew; input clk; wire[15:0]prod0,prod1,prod2,prod3,prod4,prod5,prod6,prod7,product,product1,product2; wire [15:0] res1,res2,res3,res4,res5,res6,res7,res8; wire [7:0]xn1,xn2,xn3; wire [15:0]yk2s,yk,err; wire [3:0]mantissa,exponent; wire[7:0]sum,sum1,op; wire [7:0]coeff1,coeff2,coeff3,coeff4; v8b uut1(.P(prod0),.A(xn),.B(8'd1/* coeff[0]*/),.clk(clk)); dff8 uut2(.q(xn1),.d(xn),.clk(clk)); v8b uut3(.P(prod1),.A(xn1),.B(8'd2/*coeff[1]*/),.clk(clk)); dff8 uut4(.q(xn2),.d(xn1),.clk(clk)); v8b uut5(.P(prod2),.A(xn2),.B(8'd3/*coeff[2]*/),.clk(clk)); dff8 uut6(.q(xn3),.d(xn2),.clk(clk)); v8b uut7(.P(prod3),.A(xn3),.B(8'd4/*coeff[3]*/),.clk(clk)); cladr16b uut8(.sum(res1),.x(16'b00000000),.y(prod0),.clk(clk)); cladr16b uut9(.sum(res2),.x(res1),.y(prod1),.clk(clk)); cladr16b uut10(.sum(res3),.x(res2),.y(prod2),.clk(clk)); cladr16b uut11(.sum(res4),.x(res3),.y(prod3),.clk(clk)); assign yk=res4; //output of fir filter //error calculation;error=dn-yk comp2s16b uut12(.s(yk2s),.a(yk),.clk(clk)); cladr16b uut13(.sum(err),.x(dn),.y(yk2s),.clk(clk)); assign error=err; //h(n+1)=hn+mew*error*xn assign mantissa=mew[7:4]; assign exponent=mew[3:0]; v8b uut14(.P(product),.A(xn),.B(err[7:0]),.clk(clk)); assign op={product[15:0]}; v8b uut15(.P(product1),.A(op),.B({4'b0,exponent}),.clk(clk)); assign opexponent={product1[15:0]}; v8b uut16(.P(product2),.A(op),.B({4'b0,mantissa}),.clk(clk)); assign sum1={product2[15:0]}; cladr8b uut17 (.sum(sum),.x({product1[15:8]}),.y(sum1),.clk(clk)); //sum=mew*error*xn //LMS algorithm;h(k+1)=hk+mew*error*xn cladr8b uut18(.sum(coeff1),.x(sum),.y(8'd4),.clk(clk)); cladr8b uut19(.sum(coeff2),.x(sum),.y(coeff1),.clk(clk)); cladr8b uut20(.sum(coeff3),.x(sum),.y(coeff2),.clk(clk)); cladr8b uut21(.sum(coeff4),.x(sum),.y(coeff3),.clk(clk)); //adaptive filter v8b uut22(.P(prod4),.A(xn),.B(coeff1),.clk(clk)); v8b uut24(.P(prod5),.A(xn1),.B(coeff2),.clk(clk)); v8b uut26(.P(prod6),.A(xn2),.B(coeff3),.clk(clk)); v8b uut28(.P(prod7),.A(xn3),.B(coeff4),.clk(clk)); cladr16b uut29(.sum(res5),.x(16'b00000000),.y(prod4),.clk(clk)); cladr16b uut30(.sum(res6),.x(res1),.y(prod5),.clk(clk)); cladr16b uut31(.sum(res7),.x(res2),.y(prod6),.clk(clk)); cladr16b uut32(.sum(res8),.x(res3),.y(prod7),.clk(clk)); assign yn=res8;//output of adaptive fir filter endmodule module dff8(q,d,clk); input [7:0]d; input clk; output reg [7:0] q; always@(posedge clk) begin q<=#10 d; end endmodule //8 bit vedic multiplier module v8b(P,A,B,clk); input [7:0]A,B; input clk; output [15:0]P; wire [7:0] product1,product2,product3,product4,pro3; wire [7:0]sum; wire [3:0] pro1,pro2,op1; wire [3:0] op2; v4b ut1(.P(product1),.A({A[3:0]}),.B({B[3:0]}),.clk(clk)); assign pro1=product1[3:0]; v4b ut2(.P(product2),.A({A[3:0]}),.B({B[7:4]}),.clk(clk)); v4b ut3(.P(product3),.A({A[7:4]}),.B({B[3:0]}),.clk(clk)); v4b ut4(.P(product4),.A({A[7:4]}),.B({B[7:4]}),.clk(clk)); csa_8b cuut(.d(product2),.e(product3),.f(product1[7:4]),.op1(op1),.op2(op2),.clk(clk)); assign pro2=op1; csa_8b2 auut(.d(product4),.e(op2),.op1(sum),.clk(clk)); assign pro3=sum; assign P={pro3,pro2,pro1}; endmodule //4 bit vedic multiplier module v4b(P,A,B,clk); input [3:0]A,B; input clk; output [7:0]P; wire [3:0] product1,product2,product3,product4,pro3; wire [3:0]sum; wire [1:0] pro1,pro2,op1; wire [3:0] op2; wire A0,A1,A2,A3; wire B0,B1,B2,B3; assign A0=A[0]; assign A1=A[1]; assign A2=A[2]; assign A3=A[3]; assign B0=B[0]; assign B1=B[1]; assign B2=B[2]; assign B3=B[3]; vedic2b ut1(.p(product1),.a({A1,A0}),.b({B1,B0}),.clk(clk)); assign pro1=product1[1:0]; vedic2b ut2(.p(product2),.a({A3,A2}),.b({B1,B0}),.clk(clk)); vedic2b ut3(.p(product3),.a({A1,A0}),.b({B3,B2}),.clk(clk)); vedic2b ut4(.p(product4),.a({A3,A2}),.b({B3,B2}),.clk(clk)); csa6 cuut(.d(product2),.e(product3),.f(product1[3:2]),.op1(op1),.op2(op2),.clk(clk)); assign pro2=op1; //csa4 auut(.a(product4),.b(op2),.s(sum),.c(carryout)); cladr auut(.sum(sum),.x(product4),.y(op2),.clk(clk)); //add4 auut(.p(product4),.q(op2),.ci(1'b0),.result(sum),.carry(carryout)); assign pro3=sum; assign P={pro3,pro2,pro1}; endmodule //2 bit vedic multiplier module vedic2b(p,a,b,clk); input [1:0]a,b; input clk; output reg [3:0]p; wire a0,a1,b0,b1; wire s1,s2,c1,c2; reg p0,p1,p2,p3; assign a0=a[0]; assign a1=a[1]; assign b0=b[0]; assign b1=b[1]; always@(posedge clk) begin p0=a0&b0; p1=(a1&b0)^(a0&b1); p2=(a1&b1)^{(a1&b0)&(a0&b1)}; p3=(a1&b1)&{(a1&b0)&(a0&b1)}; p={p3,p2,p1,p0}; end endmodule // csa 8bit module csa_8b(d,e,f,op1,op2,clk); input [7:0]d,e; input [3:0]f; input clk; output [3:0]op1,op2; wire [7:0] res1,res2; cladr8b c1 (.sum(res1),.x({d[7:0]}),.y({e[7:0]}),.clk(clk)); cladr8b c2 (.sum(res2),.x({4'b0000,f[3:0]}),.y(res1),.clk(clk)); assign op1={res2[3:0]}; assign op2={res2[7:4]}; endmodule //csa8b2 module csa_8b2(d,e,op1,clk); input [7:0]d; input [3:0]e; input clk; output [7:0]op1; cladr8b c1 (.sum(op1),.x({d[7:0]}),.y({4'b0000,e[3:0]}),.clk(clk)); endmodule // csa 4+4+2 bit=csa6b module csa6(d,e,f,op1,op2,clk); input [3:0]d,e; input [1:0]f; input clk; output [1:0]op1; output [3:0]op2; wire d0,d1,d2,d3; wire e0,e1,e2,e3; wire [3:0] op11,op22; cladr cla1(.sum(op11),.x(d),.y(e),.clk(clk)); cladr cla2(.sum(op22),.x(op11),.y({2'b00,f}),.clk(clk)); assign op1=op22[1:0]; assign op2={2'b00,op22[3:2]}; endmodule // carry look ahead adder 8bit module cladr8b(sum,x,y,clk); output [7:0] sum; input [7:0] x,y; input clk; parameter cin=1'b0; //output cout; wire [7:0] g,p; wire [8:0] c; assign c[0] = cin; assign g[7:0] = x[7:0] & y[7:0]; assign p[7:0] = x[7:0] ^ y[7:0]; assign c[1] = g[0] | (p[0]&cin); assign c[2] = g[1] | (p[1]&g[0]) | (p[1]&p[0]&cin); assign c[3] = g[2] | (p[2]&g[1]) | (p[2]&p[1]&g[0]) |(p[2]&p[1]&p[0]&cin); assign c[4] = g[3] | (p[3]&g[2]) | (p[3]&p[2]&g[1]) | (p[3]&p[2]&p[1]&g[0]) | (p[3]&p[2]&p[1]&p[0]&cin); assign c[5] = g[4]|(p[4]&c[4]); assign c[6] = g[5]|(p[5]&c[5]); assign c[7] = g[6]|(p[6]&c[6]); assign c[8] = g[7]|(p[7]&c[7]); assign sum[7:0] = p[7:0] ^ c[7:0]; //assign cout=c[9]; endmodule // carry look ahead adder 4bit module cladr(sum,x,y,clk); output [3:0] sum; input [3:0] x,y; input clk; parameter cin=1'b0; //output cout; wire [3:0] g,p; wire [4:0] c; assign c[0] = cin; assign g[3:0] = x[3:0] & y[3:0]; assign p[3:0] = x[3:0] ^ y[3:0]; assign c[1] = g[0] | (p[0]&cin); assign c[4] = g[3] | (p[3]&g[2]) | (p[3]&p[2]&g[1]) | (p[3]&p[2]&p[1]&g[0]) | (p[3]&p[2]&p[1]&p[0]&cin); assign sum[3:0] = p[3:0] ^ c[3:0]; //assign cout=c[4]; endmodule //// full adder //module fa( a, b, c_in,sum,c_out); //input a, b, c_in; //output sum, c_out; //wire a1, a2, a3, a4; //wire c1, c2, c3, c4; // assign a1 = (~a) & (~b) & c_in; // assign a2 = (~a) & b & (~c_in); // assign a3 = a & (~b) & (~c_in); // assign a4 = a & b & c_in; // assign sum = a1 | a2 | a3 | a4; // assign c1 = (~a) & b & c_in; // assign c2 = a & (~b) & c_in; // assign c3 = a & b & (~c_in); // assign c4 = a & b & c_in; // assign c_out = c1 | c2 | c3 | c4; //endmodule //// half adder //module ha(m,n,s,c); // input m,n; // output s,c; // wire m1,m2; // assign m1=m&(~n); // assign m2=(~m)&n; // assign s=m1|m2; // assign c=m&n; //endmodule // carry look ahead adder 16bit module cladr16b(sum,x,y,clk); output [15:0] sum; input [15:0] x,y; input clk; parameter cin=1'b0; wire [15:0] g,p; wire [16:0] c; assign c[0] = cin; assign g[15:0] = x[15:0] & y[15:0]; assign p[15:0] = x[15:0] ^ y[15:0]; assign c[1] = g[0] |(p[0]&cin); assign c[2] = g[1] |(p[1]&c[1]); assign c[3] = g[2] |(p[2]&c[2]); assign c[4] = g[3] |(p[3]&c[3]); assign c[5] = g[4] |(p[4]&c[4]); assign c[6] = g[5] |(p[5]&c[5]); assign c[7] = g[6] |(p[6]&c[6]); assign c[8] = g[7] |(p[7]&c[7]); assign c[9] = g[8] |(p[8]&c[8]); assign c[10] = g[9] |(p[9]&c[9]); assign c[11] = g[10] |(p[10]&c[10]); assign c[12] = g[11] |(p[11]&c[11]); assign c[13] = g[12] |(p[12]&c[12]); assign c[14] = g[13] |(p[13]&c[13]); assign c[15] = g[14] |(p[14]&c[14]); assign c[16] = g[15] |(p[15]&c[15]); assign sum[15:0] = p[15:0] ^ c[15:0]; //assign cout=c[16]; endmodule // comp2s128b module comp2s16b(s,a,clk); input [15:0]a; input clk; output reg[15:0]s; always@(posedge clk) begin s=~(a)+1'b1; end endmodule
The normal issues are:
1.) You have a syntax error somewhere that causes a compile to fail, but you have a previous compilation -- you aren't actually simulating changes that your making.
2.) You have a net with a typo that Verilog's default net type has conveniently declared for you, but there is no connection because it is a typo. (and this should have never been a feature in any language that has ever existed)
3.) You have connected the outputs to a set of nets that differ from the ones in your simulation.
These all come down to "you aren't compiling the correct files sucessfully" and "you aren't monitoring the correct nets".
(this is also posted in the FPGA section, but you have a CLA adder. CLA basically never makes sense in an FPGA due to routing costs. Stick to "+" or architecture-aware carry-select based adders.)
I don't get the point. The Verilog code in post #1 synthesizes to a straightforward hardware design using 16 LUT/register combinations and a carry chain.(this is also posted in the FPGA section, but you have a CLA adder. CLA basically never makes sense in an FPGA due to routing costs. Stick to "+" or architecture-aware carry-select based adders.)
There's no syntax error and no reason why it couldn't be simulated. Looks like problem in managing the simulator.
Have to look at the test bench and simulator script.
Unfortunately I missed the appended text in post #5.
// Company:
// Engineer:
// Design Name:
// Module Name: MAF
// Project Name:
// Target Devices:
// Tool versions:
// Description:
// Dependencies:
// Revision:
output [15:0]yn;
input [7:0]xn;
input [15:0]dn;
input [7:0]mew;
input clk;
wire [15:0]prod0,prod1,prod2,prod3,prod4,prod5,prod6,prod7,product,product1,product2;
wire [7:0]sum,sum1,op;
assign error=err;
//sum=mew*error*xn
//adaptive filter
endmodule
input [7:0]d;
input clk;
output reg [7:0] q;
begin
q<=#10 d;
end
endmodule
input [7:0]A,B;
input clk;
output [15:0]P;
wire [7:0]sum;
wire [3:0] op2;
assign pro2=op1;
assign pro3=sum;
endmodule
input [3:0]A,B;
input clk;
output [7:0]P;
wire [3:0]sum;
wire [3:0] op2;
wire A0,A1,A2,A3;
wire B0,B1,B2,B3;
assign A0=A[0];
assign A1=A[1];
assign A2=A[2];
assign A3=A[3];
assign B0=B[0];
assign B1=B[1];
assign B2=B[2];
assign B3=B[3];
assign pro2=op1;
assign pro3=sum;
endmodule
input [1:0]a,b;
input clk;
output reg [3:0]p;
wire a0,a1,b0,b1;
wire s1,s2,c1,c2;
reg p0,p1,p2,p3;
assign a0=a[0];
assign a1=a[1];
assign b0=b[0];
assign b1=b[1];
begin
p0=a0&b0;
p1=(a1&b0)^(a0&b1);
p={p3,p2,p1,p0};
end
endmodule
// csa 8bit
input [7:0]d,e;
input [3:0]f;
input clk;
endmodule
//csa8b2
input [7:0]d;
input [3:0]e;
input clk;
output [7:0]op1;
endmodule
input [3:0]d,e;
input [1:0]f;
input clk;
output [1:0]op1;
output [3:0]op2;
wire d0,d1,d2,d3;
wire e0,e1,e2,e3;
endmodule
output [7:0] sum;
input [7:0] x,y;
input clk;
parameter cin=1'b0;
//output cout;
wire [7:0] g,p;
wire [8:0] c;
assign c[0] = cin;
//assign cout=c[9];
endmodule
output [15:0] sum;
input [15:0] x,y;
input clk;
parameter cin=1'b0;
wire [15:0] g,p;
wire [16:0] c;
assign c[0] = cin;
endmodule
// comp2s128b
input [15:0]a;
input clk;
output reg[15:0]s;
begin
s=~(a)+1'b1;
end
endmodule
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut16/ut2/ut1>, <uut16/ut2/ut3> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut16/ut2/ut1>, <uut15/ut2/ut1> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut16/ut2/ut1>, <uut15/ut2/ut3> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut16/ut2/ut2>, <uut16/ut2/ut4> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut16/ut2/ut2>, <uut15/ut2/ut2> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut16/ut2/ut2>, <uut15/ut2/ut4> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut16/ut4/ut1>, <uut16/ut4/ut3> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut16/ut4/ut1>, <uut15/ut4/ut1> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut16/ut4/ut1>, <uut15/ut4/ut3> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut16/ut4/ut2>, <uut16/ut4/ut4> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut16/ut4/ut2>, <uut15/ut4/ut2> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut16/ut4/ut2>, <uut15/ut4/ut4> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut7/ut1/ut1>, <uut7/ut2/ut1> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut7/ut1/ut1>, <uut7/ut2/ut3> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut7/ut1/ut2>, <uut7/ut2/ut2> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut7/ut1/ut2>, <uut7/ut2/ut4> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut7/ut3/ut1>, <uut7/ut4/ut1> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut7/ut3/ut1>, <uut7/ut4/ut3> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut7/ut3/ut2>, <uut7/ut4/ut2> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut7/ut3/ut2>, <uut7/ut4/ut4> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut5/ut1/ut3>, <uut5/ut2/ut1> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut5/ut1/ut3>, <uut5/ut2/ut3> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut5/ut1/ut4>, <uut5/ut2/ut2> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut5/ut1/ut4>, <uut5/ut2/ut4> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut5/ut3/ut3>, <uut5/ut4/ut1> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut5/ut3/ut3>, <uut5/ut4/ut3> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut5/ut3/ut4>, <uut5/ut4/ut2> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut5/ut3/ut4>, <uut5/ut4/ut4> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut3/ut1/ut3>, <uut3/ut2/ut1> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut3/ut1/ut3>, <uut3/ut2/ut3> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut3/ut1/ut4>, <uut3/ut2/ut2> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut3/ut1/ut4>, <uut3/ut2/ut4> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut3/ut3/ut3>, <uut3/ut4/ut1> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut3/ut3/ut3>, <uut3/ut4/ut3> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut3/ut3/ut4>, <uut3/ut4/ut2> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut3/ut3/ut4>, <uut3/ut4/ut4> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut1/ut1/ut3>, <uut1/ut2/ut1> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut1/ut1/ut3>, <uut1/ut2/ut3> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut1/ut1/ut4>, <uut1/ut2/ut2> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut1/ut1/ut4>, <uut1/ut2/ut4> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut1/ut3/ut3>, <uut1/ut4/ut1> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut1/ut3/ut3>, <uut1/ut4/ut3> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut1/ut3/ut4>, <uut1/ut4/ut2> of unit <vedic2b> are equivalent, second instance is removed
WARNING:Xst:1989 - Unit <adaptive_filter8>: instances <uut1/ut3/ut4>, <uut1/ut4/ut4> of unit <vedic2b> are equivalent, second instance is removed
Optimizing unit <adaptive_filter8> ...
Optimizing unit <dff8> ...
Optimizing unit <cladr16b> ...
Optimizing unit <comp2s16b> ...
Optimizing unit <cladr8b> ...
Optimizing unit <vedic2b> ...
WARNING:Xst:1710 - FF/Latch <uut7/ut1/ut3/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut7/ut1/ut4/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut7/ut1/ut4/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut7/ut3/ut1/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut7/ut3/ut1/p_1> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut7/ut3/ut1/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut7/ut3/ut1/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut7/ut3/ut2/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut7/ut3/ut2/p_1> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut5/ut1/ut3/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut5/ut1/ut3/p_1> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut5/ut1/ut3/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut5/ut1/ut3/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut5/ut1/ut4/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut5/ut1/ut4/p_1> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut5/ut1/ut4/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut5/ut1/ut4/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut5/ut3/ut3/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut5/ut3/ut3/p_1> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut5/ut3/ut3/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut5/ut3/ut3/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut5/ut3/ut4/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut5/ut3/ut4/p_1> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut5/ut3/ut4/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut16/ut2/ut1/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut16/ut2/ut1/p_1> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut16/ut2/ut1/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut16/ut2/ut1/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut16/ut2/ut2/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut16/ut2/ut2/p_1> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut16/ut2/ut2/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut16/ut2/ut2/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut16/ut4/ut1/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut16/ut4/ut1/p_1> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut16/ut4/ut1/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut16/ut4/ut1/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut16/ut4/ut2/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut16/ut4/ut2/p_1> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut16/ut4/ut2/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut16/ut4/ut2/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut7/ut1/ut1/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut7/ut1/ut1/p_1> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut7/ut1/ut1/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut7/ut1/ut1/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut7/ut1/ut2/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut7/ut1/ut2/p_1> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut7/ut1/ut2/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut7/ut1/ut2/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut7/ut1/ut3/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut1/ut1/ut1/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut1/ut1/ut1/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut1/ut1/ut2/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut1/ut1/ut2/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut1/ut1/ut3/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut1/ut1/ut3/p_1> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut1/ut1/ut3/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut1/ut1/ut3/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut1/ut1/ut4/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut1/ut1/ut4/p_1> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut1/ut1/ut4/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut1/ut1/ut4/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut1/ut3/ut1/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut1/ut3/ut1/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut1/ut3/ut2/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut1/ut3/ut2/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut1/ut3/ut3/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut1/ut3/ut3/p_1> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut1/ut3/ut3/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut1/ut3/ut3/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut1/ut3/ut4/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut1/ut3/ut4/p_1> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut1/ut3/ut4/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut1/ut3/ut4/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut5/ut3/ut4/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut3/ut1/ut1/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut3/ut1/ut1/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut3/ut1/ut2/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut3/ut1/ut2/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut3/ut1/ut3/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut3/ut1/ut3/p_1> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut3/ut1/ut3/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut3/ut1/ut3/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut3/ut1/ut4/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut3/ut1/ut4/p_1> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut3/ut1/ut4/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut3/ut1/ut4/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut3/ut3/ut1/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut3/ut3/ut1/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut3/ut3/ut2/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut3/ut3/ut2/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut3/ut3/ut3/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut3/ut3/ut3/p_1> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut3/ut3/ut3/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut3/ut3/ut3/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut3/ut3/ut4/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut3/ut3/ut4/p_1> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut3/ut3/ut4/p_2> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut3/ut3/ut4/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:2677 - Node <uut12/s_15> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut12/s_14> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut12/s_13> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut12/s_12> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut12/s_11> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut12/s_10> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut12/s_9> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut12/s_8> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut7/ut3/ut4/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut7/ut3/ut4/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut7/ut3/ut4/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut7/ut3/ut4/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut7/ut3/ut3/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut7/ut3/ut3/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut7/ut3/ut2/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut7/ut3/ut2/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut4/ut4/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut4/ut4/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut4/ut4/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut4/ut4/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut4/ut3/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut4/ut3/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut4/ut3/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut4/ut3/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut4/ut2/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut4/ut2/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut4/ut2/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut4/ut2/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut4/ut1/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut4/ut1/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut4/ut1/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut4/ut1/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut3/ut4/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut3/ut4/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut3/ut4/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut3/ut4/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut3/ut3/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut3/ut3/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut3/ut2/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut3/ut2/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut2/ut4/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut2/ut4/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut2/ut4/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut2/ut4/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut2/ut3/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut2/ut3/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut2/ut2/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut14/ut2/ut2/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut15/ut1/ut3/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut15/ut1/ut3/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut15/ut1/ut2/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut15/ut1/ut2/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut15/ut1/ut1/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut15/ut1/ut1/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut15/ut1/ut1/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut15/ut1/ut1/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut16/ut3/ut4/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut16/ut3/ut4/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut16/ut3/ut4/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut16/ut3/ut4/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut16/ut3/ut3/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut16/ut3/ut3/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut16/ut3/ut2/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut16/ut3/ut2/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut4/ut4/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut4/ut4/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut4/ut4/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut4/ut4/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut4/ut3/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut4/ut3/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut4/ut3/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut4/ut3/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut4/ut2/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut4/ut2/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut4/ut2/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut4/ut2/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut4/ut1/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut4/ut1/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut4/ut1/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut4/ut1/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut3/ut4/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut3/ut4/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut3/ut4/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut3/ut4/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut3/ut3/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut3/ut3/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut3/ut3/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut3/ut3/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut3/ut2/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut3/ut2/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut3/ut2/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut3/ut2/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut3/ut1/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut3/ut1/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut3/ut1/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut3/ut1/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut2/ut4/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut2/ut4/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut2/ut4/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut2/ut4/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut2/ut3/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut2/ut3/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut2/ut3/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut2/ut3/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut2/ut2/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut2/ut2/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut2/ut2/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut2/ut2/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut2/ut1/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut2/ut1/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut2/ut1/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut2/ut1/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut1/ut4/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut1/ut4/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut1/ut4/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut1/ut4/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut1/ut3/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut1/ut3/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut1/ut3/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut1/ut3/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut1/ut2/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut1/ut2/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut1/ut2/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut1/ut2/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut1/ut1/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut1/ut1/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut1/ut1/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut22/ut1/ut1/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut4/ut4/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut4/ut4/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut4/ut4/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut4/ut4/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut4/ut3/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut4/ut3/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut4/ut3/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut4/ut3/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut4/ut2/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut4/ut2/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut4/ut2/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut4/ut2/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut4/ut1/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut4/ut1/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut4/ut1/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut4/ut1/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut3/ut4/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut3/ut4/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut3/ut4/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut3/ut4/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut3/ut3/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut3/ut3/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut3/ut3/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut3/ut3/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut3/ut2/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut3/ut2/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut3/ut2/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut3/ut2/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut3/ut1/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut3/ut1/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut3/ut1/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut3/ut1/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut2/ut4/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut2/ut4/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut2/ut4/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut2/ut4/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut2/ut3/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut2/ut3/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut2/ut3/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut2/ut3/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut2/ut2/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut2/ut2/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut2/ut2/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut2/ut2/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut2/ut1/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut2/ut1/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut2/ut1/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut2/ut1/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut1/ut4/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut1/ut4/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut1/ut4/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut1/ut4/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut1/ut3/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut1/ut3/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut1/ut3/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut1/ut3/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut1/ut2/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut1/ut2/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut1/ut2/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut1/ut2/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut1/ut1/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut1/ut1/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut1/ut1/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut24/ut1/ut1/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut4/ut4/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut4/ut4/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut4/ut4/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut4/ut4/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut4/ut3/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut4/ut3/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut4/ut3/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut4/ut3/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut4/ut2/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut4/ut2/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut4/ut2/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut4/ut2/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut4/ut1/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut4/ut1/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut4/ut1/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut4/ut1/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut3/ut4/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut3/ut4/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut3/ut4/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut3/ut4/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut3/ut3/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut3/ut3/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut3/ut3/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut3/ut3/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut3/ut2/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut3/ut2/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut3/ut2/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut3/ut2/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut3/ut1/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut3/ut1/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut3/ut1/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut3/ut1/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut2/ut4/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut2/ut4/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut2/ut4/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut2/ut4/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut2/ut3/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut2/ut3/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut2/ut3/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut2/ut3/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut2/ut2/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut2/ut2/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut2/ut2/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut2/ut2/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut2/ut1/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut2/ut1/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut2/ut1/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut2/ut1/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut1/ut4/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut1/ut4/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut1/ut4/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut1/ut4/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut1/ut3/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut1/ut3/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut1/ut3/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut1/ut3/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut1/ut2/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut1/ut2/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut1/ut2/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut1/ut2/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut1/ut1/p_3> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut1/ut1/p_2> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut1/ut1/p_1> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:2677 - Node <uut26/ut1/ut1/p_0> of sequential type is unconnected in block <adaptive_filter8>.
WARNING:Xst:1710 - FF/Latch <uut28/ut3/ut2/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut28/ut3/ut2/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut28/ut3/ut1/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut28/ut3/ut1/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut28/ut1/ut2/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut28/ut1/ut2/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut28/ut1/ut1/p_3> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1895 - Due to other FF/Latch trimming, FF/Latch <uut28/ut1/ut1/p_0> (without init value) has a constant value of 0 in block <adaptive_filter8>. This FF/Latch will be trimmed during the optimization process.
- I don't understand why elementary operations like carry look-ahead adders are coded explicitly instead of using arithmetic expressions and let the compiler implement it.
You get warnings about inputs not driving logic and undriven nets, looks like an error in the filter topology.
- I'm missing a description of the implemented "adaptive filter", e.g. a block diagram to check the code against it
Hello FM
I am attaching results for you.
I think there is some problem with variable not getting link with other module written in code.
I have already posted my code in post 5.
//8 bit vedic multiplier
module v8b(P,A,B,clk);
input [7:0]A,B;
input clk;
output [15:0]P;
wire [7:0] product1,product2,product3,product4,pro3;
wire [7:0]sum;
wire [3:0] pro1,pro2,op1;
wire [3:0] op2;
v4b ut1(.P(product1),.A({A[3:0]}),.B({B[3:0]}),.clk(clk));
assign pro1=product1[3:0];
v4b ut2(.P(product2),.A({A[3:0]}),.B({B[7:4]}),.clk(clk));
v4b ut3(.P(product3),.A({A[7:4]}),.B({B[3:0]}),.clk(clk));
v4b ut4(.P(product4),.A({A[7:4]}),.B({B[7:4]}),.clk(clk));
csa_8b cuut(.d(product2),.e(product3),.f(product1[7:4]),.op1(op1),.op2(op2),.clk(clk));
assign pro2=op1;
csa_8b2 auut(.d(product4),.e(op2),.op1(sum),.clk(clk));
assign pro3=sum;
assign P={pro3,pro2,pro1};
endmodule
I see that you have presently implemented fixed instead of adaptive filter coefficients, so the filter should output non-'X' values after some clock cycles. But you don't show any simulation results that are running longer than 1 cycle. So we can't see meaningful output.
In the final design, you'll need a mechanism that delays the adaptive logic until all unknown values have disappeared.
If you're unsure about correct operation of your "homemade" adders, you'll test them separately before putting the design together.
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 module cladr(sum,x,y,clk); output [3:0] sum; input [3:0] x,y; input clk; parameter cin=1'b0; //output cout; wire [3:0] g,p; wire [4:0] c; assign c[0] = cin; assign g[3:0] = x[3:0] & y[3:0]; assign p[3:0] = x[3:0] ^ y[3:0]; assign c[1] = g[0] | (p[0]&cin); assign c[4] = g[3] | (p[3]&g[2]) | (p[3]&p[2]&g[1]) | (p[3]&p[2]&p[1]&g[0]) | (p[3]&p[2]&p[1]&p[0]&cin); assign sum[3:0] = p[3:0] ^ c[3:0]; //assign cout=c[4]; endmodule
