[moved] Vhdl testbench for fft
vhdlpro
Newbie level 1
Newbie level 1
library ieee ;
use ieee.std_logic_1164.all ;
use ieee.numeric_std.all ;
use IEEE.std_logic_textio.all;
package butter_lib is
signal ram_data,d2,d3,d4,d5,d6,d7,d8,d9,d10,d11,d12,d13,d14,d15,d16,d17,d18,d19,out_data : std_logic_vector(31 downto 0) := (others => '0') ;
signal data_rom , rom_ff : std_logic_vector(31 downto 0) ;
signal clock_main , reset , enbl , clock : std_logic := '0' ;
signal c0 , c1 , c2 , c3 , c0_c1 , c2_c3 , c0_c2 , c1_c3 : std_logic ;
signal c0_and,c1_and,c2_and,c3_and,c0_c1and,c2_c3and,c0_c2and,c1_c3and : std_logic ;
signal reset_count : std_logic ;
type state is (reset1 , reset2 , reset3 , reset4 , reset5 , reset6 , reset7) ;
signal final_sum : std_logic_vector (31 downto 0) := (others => '0') ;
signal shift , finish_sum , signbit , normalise , end_all , a_small , addsub ,sum_out2 , shift_done , done , num_rec , setbit ,  addpulse : std_logic := '0' ;
signal shift_outa , swap_num2 : std_logic_vector ( 31 downto 0 ) := (others => '0') ;
signal swap_num1 , sum_out : std_logic_vector (32 downto 0) := (others => '0') ;
signal sub2 : std_logic_vector (8 downto 0) := (others => '0') ;
signal suba : std_logic_vector (8 downto 0) := (others => '0') ;
signal exp : std_logic_vector (7 downto 0) := (others => '0') ;
signal rst , enswap , ensub , enshift , finsub , finswap , finshift , numzero : std_logic := '0' ;
signal zerodetect : std_logic_vector(1 downto 0) ;
signal changea : std_logic ;
signal final_sumb : std_logic_vector (31 downto 0) := (others => '0') ;
signal shiftb , finish_sumb , signbitb , normaliseb , end_allb , a_smallb , addsubb,sum_out2b , shift_doneb , doneb , num_recb , setbitb ,  addpulseb , clockb : std_logic := '0' ;
signal shift_outb , swap_num2b : std_logic_vector ( 31 downto 0 ) := (others => '0') ;
signal swap_num1b , sum_outb : std_logic_vector (32 downto 0) := (others => '0') ;
signal sub2b : std_logic_vector (8 downto 0) := (others => '0') ;
signal subb : std_logic_vector (8 downto 0) := (others => '0') ;
signal expb: std_logic_vector (7 downto 0) := (others => '0') ;
signal rstb , enswapb , ensubb , enshiftb , finsubb , finswapb , finshiftb , numzerob , clock_mainb , resetb , enblb : std_logic := '0' ;
signal zerodetectb : std_logic_vector(1 downto 0) ;
signal changeb : std_logic ;
signal incr , clear , io_mode , staged , iod : std_logic ;
signal butterfly,fftadd_rd,shift1,shift3,shift4,shift5,shift6,ram_wr,ram_rd,io_add : std_logic_vector(3 downto 0) := (others => '0') ;
signal fftd , fft_en , ip , op , init : std_logic ;
signal stage : std_logic_vector(1 downto 0) ;
--signal clock_main,c0,c1,c2,c3,c0_c1,c2_c3,c0_c2,c1_c3 : std_logic ;
signal preset,disable,c0_en,rom_en,romgen_en : std_logic ;
signal clk_count : std_logic_vector(2 downto 0) ;
signal enbw , enbor : std_logic ;
signal data_io : std_logic_vector(31 downto 0) := (others => '0') ;
signal rom_add : std_logic_vector(2 downto 0) ;
type state_values is (st0 , st1 , st2 ,  st3) ;
signal pres_state1 , next_state1 : state_values ;
signal butterfly_iod : std_logic_vector(3 downto 0) ;
signal cyc_clear : std_logic ;
signal add_rd , add_wr : std_logic_vector(3 downto 0) ;
end butter_lib ;
--TESTBENCH FOR THE ENTIRE PROCESSOR. FOR SYNTHESIS THIS FILE WITHOUT
-- THE STIMULUS PART IS GIVEN AS THE TOP LEVEL ENTITY.
library ieee ;
use ieee.std_logic_arith.all ;
use work.butter_lib.all ;
use ieee.std_logic_unsigned.all ;
entity synth_test is
end synth_test ;
architecture rtl of synth_test is
signal shft , waves : std_logic_vector(3 downto 0) ;
component subtractor
  port (
       a : in std_logic_vector (31 downto 0) ;
       b : in std_logic_vector (31 downto 0) ;
       clock , rst_sub , sub_en : in std_logic ;
       a_smaller , fin_sub , num_zero : out std_logic ;
       zero_detect : out std_logic_vector(1 downto 0) ;
       sub : out std_logic_vector (8 downto 0);
       change : out std_logic ) ;
end component ;
component swap
 port (
       clock : in std_logic ;
       rst_swap , en_swap : in std_logic ;
       finish_swap : out std_logic ;
       d : out std_logic_vector (31 downto 0) ;
       large_exp : out std_logic_vector (7 downto 0) ;
       c  : out std_logic_vector (32 downto 0 ) ) ;
end component ;
component shift2
 port (
       sub_control : in std_logic_vector (8 downto 0) ;
       c_in  : in std_logic_vector (32 downto 0) ;
       shift_out : out std_logic_vector (31 downto 0) ;
       clock , shift_en , rst_shift : in std_logic ;
       finish_out : out std_logic ) ;
end component ;
component control_main
 port (
       a_small , sign_a , sign_b : in std_logic ;
       sign_out , add_sub , reset_all : out std_logic ;
       en_sub , en_swap , en_shift , addpulse , normalise : out std_logic ;
       fin_sub , fin_swap , finish_shift , add_finish , end_all : in std_logic ;
       clock_main , clock , reset , enbl , zero_num , change : in std_logic ) ;
end component ;
component summer
 port (
       num1 , num2 : in std_logic_vector (31 downto 0) ;
       exp : in std_logic_vector (7 downto 0) ;
       addpulse_in , addsub , rst_sum : in std_logic ;
       add_finish : out std_logic ;
       sumout : out std_logic_vector ( 32 downto 0) ) ;
end component ;
component normalize
 port (
      a , b : in std_logic_vector (31 downto 0) ;
      numb : in std_logic_vector (32 downto 0) ;
      signbit , addsub , clock , en_norm , rst_norm  : in std_logic  ;
      zero_detect : in std_logic_vector(1 downto 0) ;
      exit_n : out std_logic ;
      normal_sum : out std_logic_vector (31 downto 0) ) ;
end component ;
component but_gen
port (
      add_incr , add_clear , stagedone : in std_logic ;
      but_butterfly : out std_logic_vector(3 downto 0) ) ;
end component ;
component stage_gen
port (
      add_staged , add_clear : in std_logic ;
      st_stage : out std_logic_vector(1 downto 0) ) ;
end component ;
component iod_staged is
port (
      but_fly : in std_logic_vector(3 downto 0) ;
      stage_no : in std_logic_vector(1 downto 0) ;
      add_incr , io_mode  : in std_logic ;
      add_iod , add_staged , add_fftd : out std_logic ;
      butterfly_iod : out std_logic_vector(3 downto 0) ) ;
end component ;
component baseindex
port (
      ind_butterfly : in std_logic_vector(3 downto 0) ;
      ind_stage : in std_logic_vector(1 downto 0) ;
      add_fft : in std_logic ;
      fftadd_rd : out std_logic_vector(3 downto 0) ;
      c0 , c1 , c2 , c3 : in std_logic ) ;
end component ;
component ioadd_gen
port (
      io_butterfly : in std_logic_vector(3 downto 0) ;
      add_iomode , add_ip , add_op : in std_logic ;
      base_ioadd : out std_logic_vector(3 downto 0) ) ;
end component ;
component mux_add
port (
      a , b : in std_logic_vector(3 downto 0) ;
      sel : in std_logic ;
      q : out std_logic_vector(3 downto 0) ) ;
end component ;
component ram_shift
port (
      data_in : in std_logic_vector(3 downto 0) ;
      clock_main : in std_logic ;
      data_out : out std_logic_vector(3 downto 0) ) ;
end component ;
component cycles
port (
      clock_main , preset , c0_en , cycles_clear : in std_logic ;
      waves : out std_logic_vector(3 downto 0) ) ;
end component ;
component counter
port (
      c : out std_logic_vector(2 downto 0) ;
      disable , clock_main , reset : in std_logic) ;
end component ;
component mult_clock
port (
      clock_main , mult1_c0 , mult1_iomode , mult_clear : in std_logic ;
      mult1_addincr : out std_logic ) ;
end component ;
component cont_gen
port (
      con_staged , con_iod , con_fftd , con_init : in std_logic ;
      con_ip , con_op , con_iomode , con_fft : out std_logic ;
      con_enbw , con_enbor , c0_enable , con_preset : out std_logic ;
      con_clear , disable : out std_logic ;
      c0 , clock_main : in std_logic ;
      en_rom , en_romgen , reset_counter : out std_logic ;
      con_clkcount : in std_logic_vector(2 downto 0) ) ;
end component ;
component and_gates
port (
      waves_and : in std_logic_vector(3 downto 0) ;
      clock_main , c0_en : in std_logic ;
      c0,c1,c2,c3 : out std_logic ;
      c0_c1,c2_c3,c0_c2,c1_c3 : out std_logic ) ;
end component ;
component r_block
port (
       data : in std_logic_vector(31 downto 0) ;
       trigger : in std_logic ;
       r_out : out std_logic_vector(31 downto 0) ) ;
end component ;
component l_block
port (
       data_l : in std_logic_vector(31 downto 0) ;
       trigger_l : in std_logic ;
       l_out : out std_logic_vector(31 downto 0) ) ;
end component ;
component level_edge
 port (
       data_edge : in std_logic_vector(31 downto 0) ;
       trigger_edge : in std_logic ;
       edge_out : out std_logic_vector(31 downto 0) ) ;
end component ;
component mux
port (
       d0 , d1 : in std_logic_vector(31 downto 0) ;
       mux_out : out std_logic_vector(31 downto 0) ;
       choose : in std_logic ) ;
end component ;
component negate
port (
       neg_in : in std_logic_vector(31 downto 0) ;
       neg_en , clock_main : in std_logic ;
       neg_out : out std_logic_vector(31 downto 0) ) ;
end component ;
component multiply
port(
      num_mux , num_rom : in std_logic_vector(31 downto 0) ;
      mult_out : out std_logic_vector(31 downto 0) ) ;
end component ;
component divide
port (
       data_in : in std_logic_vector(31 downto 0) ;
       data_out : out std_logic_vector(31 downto 0) ) ;
end component ;
component romadd_gen is
port (
      io_rom,c0,c1,c2,c3 : in std_logic ;
      stage_rom : in std_logic_vector(1 downto 0) ;
      butterfly_rom : in std_logic_vector(3 downto 0) ;
      romadd : out std_logic_vector(2 downto 0) ;
      romgen_en : in std_logic );
end component ;
component reg_dpram is
port (
      data_fft , data_io : in std_logic_vector (31 downto 0);
      q : out std_logic_vector (31 downto 0);
      clock , io_mode : in std_logic;
      we , re : in std_logic;
      waddress: in std_logic_vector (3 downto 0);
      raddress: in std_logic_vector (3 downto 0));
end component ;
component rom is
port (
      clock , en_rom : in std_logic ;
      romadd : in std_logic_vector(2 downto 0) ;
      rom_data : out std_logic_vector(31 downto 0) ) ;
end component ;
component print_result is
port (clock,op : in std_logic ;
      fin_res : out std_logic_vector(31 downto 0) ;
      result : in std_logic_vector(31 downto 0));
end component ;
    signal ind_butterfly : std_logic_vector (3 downto 0);
    signal ind_stage     : std_logic_vector (1 downto 0);
    signal add_fft       : std_logic;
    signal fftadd_rd     : std_logic_vector (3 downto 0);
    signal c3            : std_logic;
    signal clock_main : std_logic:= '0';
    signal final_op :  std_logic_vector(31 downto 0) ;
    constant clock_Period : time := 100 ns; -- EDIT put right period here
    signal clock : std_logic := '0';
begin
result : print_result port map (clock_main,op,final_op,ram_data) ;
but : but_gen port map (incr , clear , staged ,butterfly_iod) ;
stg : stage_gen port map (staged , clear , stage) ;
iod_stgd : iod_staged port map(butterfly_iod,stage,incr,io_mode,iod,staged,fftd,butterfly) ;
base : baseindex port map (butterfly , stage , fft_en , fftadd_rd , c0 , c1 , c2 , c3) ;
ioadd : ioadd_gen port map (butterfly , io_mode , ip , op , io_add) ;
ram_shift1 : ram_shift port map (fftadd_rd , clock_main , shift1) ;
ram_shift2 : ram_shift port map (shift1 , clock_main , shft) ;
ram_shift3 : ram_shift port map (shft , clock_main , shift3) ;
ram_shift4 : ram_shift port map (shift3 , clock_main ,shift4) ;
ram_shift5 : ram_shift port map (shift4 , clock_main , shift5) ;
--ram_shift6 : ram_shift port map (shift5 , clock_main , shift6) ;
multx1 : mux_add port map (shift5 , io_add , io_mode , ram_wr) ;
multx2 : mux_add port map (fftadd_rd , io_add , io_mode , ram_rd) ;
cyc : cycles port map (clock_main , preset , c0_en , cyc_clear , waves) ;
gates : and_gates port map(waves,clock_main,c0_en,c0,c1,c2,c3,c0_c1,c2_c3,c0_c2,c1_c3) ;
cnt : counter port map (clk_count , disable , clock_main , reset_count) ;
mux_clock : mult_clock port map (clock_main , c0 , io_mode , clear , incr) ;
control : cont_gen port map (staged , iod , fftd , init , ip , op , io_mode , fft_en ,
enbw , enbor , c0_en , preset , clear , disable , c0 , clock_main ,rom_en,romgen_en,reset_count,clk_count) ;
reg_ram : reg_dpram port map (out_data,data_io,ram_data,clock_main,io_mode,enbw,enbor,ram_wr,ram_rd) ;
f1 : r_block port map (ram_data , c0 , d2) ;
f2 : l_block port map (ram_data , c1 , d3) ;
f3 : r_block port map (ram_data , c2 , d4) ;
f4 : r_block port map (ram_data , c3 , d5) ;
f5 : r_block port map (d8 , c1_c3 , d9) ;
f6 : l_block port map (d8 , c0_c2 , d10) ;
f7 : l_block port map (d12 , c3 , d13) ;
f8 : l_block port map (d12 , c1 , d14) ;
f9 : r_block port map (d17 , clock_main , d18) ;
f10: r_block port map (data_rom , clock_main , rom_ff) ;
mux1 : mux port map (d2 , d3 , d6 , c2_c3) ;
mux2 : mux port map (d4 , d5 , d7 , c1_c3) ;
mux3 : mux port map (d13 , d14 , d15 , c1_c3) ;
neg1 : negate port map (d10 , c0_c1 ,clock_main , d11) ;
neg2 : negate port map (d15 , c0_c1 ,clock_main , d16) ;
mult1 : multiply port map (d6 , rom_ff , clock_main , d8) ;
div : divide port map (d18 , d19) ;
f11 : level_edge port map (d19,clock_main,out_data) ;
rom_add1 : romadd_gen port map (io_mode,c0,c1,c2,c3,stage,butterfly,rom_add,romgen_en) ;
rom1 : rom port map (clock ,rom_en,rom_add,data_rom) ;
b11 : subtractor port map ( d16 , d7 , clock , rstb , ensubb , a_smallb , finsubb , numzerob , zerodetectb , subb ,  changeb) ;
b2 : swap port map ( a=>d16 , b=>d7 , clock=>clock , rst_swap=>rstb , en_swap=>enswapb , finish_swap=>finswapb , d=>swap_num2b , large_exp=>expb , c=>swap_num1b ) ;
b4 : shift2 port map (sub_control=>subb , c_in=>swap_num1b , shift_out=>shift_outb , clock=>clock , shift_en=>enshiftb,
rst_shift=>rstb , finish_out=>finshiftb ) ;
b5 : control_main port map ( a_smallb , d16(31) , d7(31) , signbitb , addsubb , rstb , ensubb ,
enswapb , enshiftb , addpulseb , normaliseb , finsubb , finswapb , finshiftb ,finish_sumb , end_allb ,
clock_main , clock , reset , enbl , numzerob , changeb ) ;
b6 : summer port map ( shift_outb , swap_num2b , expb , addpulseb , addsubb , rstb , finish_sumb , sum_outb ) ;
b7 : normalize port map (d16 , d7 , sum_outb , expb , signbitb , addsubb , clock , normaliseb , rstb , zerodetectb , end_allb , d17) ;
a1 : subtractor port map ( d9 ,  d11 , clock , rst , ensub , a_small , finsub , numzero , zerodetect , suba , changea) ;
a2 : swap port map (d9 ,d11 ,clock ,rst ,enswap , finswap ,swap_num2 , exp , swap_num1 ) ;
a4 : shift2 port map (suba ,swap_num1 ,shift_outa ,clock , enshift , rst , finshift ) ;
a5 : control_main port map ( a_small , d9(31) , d11(31) , signbit , addsub , rst , ensub ,
enswap , enshift , addpulse , normalise , finsub , finswap , finshift ,finish_sum , end_all ,
clock_main , clock , reset , enbl , numzero , changea ) ;
a6 : summer port map ( shift_outa , swap_num2 , exp , addpulse , addsub , rst , finish_sum , sum_out ) ;
a7 : normalize port map (d9 , d11 , sum_out , exp , signbit , addsub , clock , normalise , rst , zerodetect , end_all , d12) ;
process
variable i : integer := 0 ;
begin
for i in 1 to 1000 loop
clock <= '1' ;
wait for 5 ns ;
clock <= '0' ;
wait for 5 ns ;
end loop ;
end process ;
process
variable j : integer := 0 ;
begin
for j in 1 to 1000 loop
clock_main <= '1' ;
wait for 200 ns ;
clock_main <= '0' ;
wait for 200 ns ;
end loop ;
end process ;
process IS
variable l , l2 :LINE ;
variable q , p :integer := 0 ;
variable count :integer ;
variable t_a , t_b :std_logic_vector (31 downto 0);
variable space :character ;
file vector_file :text open read_mode is "rom_ram.vhd" ;
begin
while not endfile(vector_file) loop
--for count in 1 to 16 loop
q := 31 ;
readline(vector_file , l2) ;
for p in 1 to 32 loop -- data from RAM
read(l2 , t_b(q)) ;
q := q - 1 ;
end loop ;
q := 31 ;
data_io <= t_b(31 downto 0) ;
wait for 400 ns ;
end loop ;
wait for 8 ms ;
---wait for 650 ns ;
end process;
--- process to reset
process
begin
reset <= '1' ;
enbl <= '1' ;
wait for 10 ns ;
reset <= '0' ;
wait ;
end process ;
process
begin
init <= '1' ;
wait for 15 ns ;
init <= '0' ;
wait ;
end process ;
end rtl;
synth_test.vhd:404:18: no declaration for "line"
synth_test.vhd:409:19: no declaration for "text"
synth_test.vhd:409:6: file subtype expected for a file declaration
synth_test.vhd:412:11: no declaration for "endfile"
synth_test.vhd:415:1: no declaration for "readline"
synth_test.vhd:415:10: file "vector_file" is not visible here
synth_test.vhd:418:5: can't find a subprogram for this overload call
these types of errors are found.. can u help me to fi
you need the use std.textio.all; line to define all the basic I/O stuff. The std_logic_textio is a synopsys package it's not an official IEEE package.
but it is useful for outputting std_logic_vectors.
