ndahal
Newbie
I am trying to figure out an easy way to build tilted cylinder in HFSS. I need to build a 2-turn square loop antenna and I need to tilt each wire of the loop so that I can progressively build the pitch. I see that you can rotate the cylinder which can be used to tilt it but I was wondering if there was an easier way. I need to build five 2-turn square loop antennas and tiling each cylinder for that is a lot of work.
Please let me know.
Thank you!
Please let me know.
Thank you!
