[Moved] Tilted Cylinder in HFSS
ndahal
Newbie
I am trying to figure out an easy way to build tilted cylinder in HFSS. I need to build a 2-turn square loop antenna and I need to tilt each wire of the loop so that I can progressively build the pitch. I see that you can rotate the cylinder which can be used to tilt it but I was wondering if there was an easier way. I need to build five 2-turn square loop antennas and tiling each cylinder for that is a lot of work.
Please let me know.
Thank you!
Welcome ndahal,
You can join all of the objects in the square loop together. You can then rotate the entire object around a specified axis.
Good Luck!
But I want each object in the loop to tilt up in the z-direction. Square Loop Antenna.png
I have attached 4NEC2 model of the antenna to this post. The attachment only shows one loop of the square-loop antenna. Objects 1, 2, 3, 4 and 5 each tilt up in the z-direction.
Thank you for your response!
