BartlebyScrivener
Member level 5
- Joined
- Feb 8, 2012
- Messages
- 90
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 2,081
I have tried to design a third order active filter with a cut off freq of 20kHz. Using 10 kOhm resistors, I make that the capacitors should be 795pF using 2*pi*f = 1/CR
I made a folded cascode amplifier, with an output buffer stage
then added a first order filter to the output
then added the first order to the input, and the cap to the output.
But I seem to get a first order response when I do an ac sweep? Also, the -3dB point is around 1kHz instead of 20kHz.
What am I doing wrong?! Thanks.
