[SOLVED] [Moved] tcpip code help needed
john2020
Full Member level 5
Full Member level 5
hi
how can i send a datagram containing “How are you” via TCP/IP socket to device located at 192.168.10.5. Then listen for a response and print the response?please help me with example.??
Re: tcpip code help needed
I dont know JAVA :-(
any C sample code would help me understand better?
i am trying to write this application using embedded c program..newbie to networking,so can u help me with some code snippets here?
The example
https://www.codeproject.com/Articles/11740/A-simple-UDP-time-server-and-client-for-beginners
is in C but not embedded
in the case of embedded systems the code/libraries used depends upon the target microcontroler - for example in the Microchip MLA TCP/IP library (look under Legacy MLA)
https://www.microchip.com/pagehandler/en-us/devtools/mla/
the file UCP.C contains functions for sending and receiving UDP datagrams using Microchip products
which microcontroller do you intend to use ?
Instead of UDP, any TCPIP socket code you have to understand better? Any microcontroller code would be enough to understand the code flow.
Embedded C, then why is this thread posted in the "PC Programming and Interfacing" section? :evil:
Thread moved to Microcontrollers section.
BigDog
