[Moved]: TCAD Synopsys device model file problem
amoghshrivastava
Newbie level 2
Newbie level 2
I created structure of tunnel field effect transistor using TCAD Synopsys doping and meshing already done but after simulation using des.cmd file ,I am unable to get proper current(Id Vg Characterisitics )
due to some missing model syntax in the physics of device ,
kindly anyone help me for model or syntax of model behind tunnel FET to get current characteristics .
Thanking you
Re: TCAD Synopsys device model file problem
Has this already been solved (see title on top) ... or not?
I removed the [SOLVED]; unfortunately cannot help myself, sorry.
I'd suggest you show your des.cmd file and explicitely tell what you are missing.
Hope you get help here! Good luck!
