pic+gsm
I am not using the (FATFS or any known file stems), I have managed to find one open source code/tutorial on file systems which I am working with, like I said I can read any files such as (“TEST.TXT”) my problem is I can’t access or display the root directory files of the sd card.
this is the code i am trying to work with.
i have been using the **broken link removed**
but my question is there a way i can read boot from the sd without the .img file?
pleas someone help me
#include <stdio.h>
#include <stdlib.h>
typedef struct {
unsigned char first_byte;
unsigned char start_chs[3];
unsigned char partition_type;
unsigned char end_chs[3];
unsigned long start_sector;
unsigned long length_sectors;
} __attribute((packed)) PartitionTable;
typedef struct {
unsigned char jmp[3];
char oem[8];
unsigned short sector_size;
unsigned char sectors_per_cluster;
unsigned short reserved_sectors;
unsigned char number_of_fats;
unsigned short root_dir_entries;
unsigned short total_sectors_short; // if zero, later field is used
unsigned char media_descriptor;
unsigned short fat_size_sectors;
unsigned short sectors_per_track;
unsigned short number_of_heads;
unsigned long hidden_sectors;
unsigned long total_sectors_long;
unsigned char drive_number;
unsigned char current_head;
unsigned char boot_signature;
unsigned long volume_id;
char volume_label[11];
char fs_type[8];
char boot_code[448];
unsigned short boot_sector_signature;
} __attribute((packed)) Fat16BootSector;
typedef struct {
unsigned char filename[8];
unsigned char ext[3];
unsigned char attributes;
unsigned char reserved[10];
unsigned short modify_time;
unsigned short modify_date;
unsigned short starting_cluster;
unsigned long file_size;
} __attribute((packed)) Fat16Entry;
void print_file_info(Fat16Entry *entry) {
switch(entry->filename[0]) {
case 0x00:
return; // unused entry
case 0xE5:
printf("Deleted file: [?%.7s.%.3s]\n", entry->filename+1, entry->ext);
return;
case 0x05:
printf("File starting with 0xE5: [%c%.7s.%.3s]\n", 0xE5, entry->filename+1, entry->ext);
break;
case 0x2E:
printf("Directory: [%.8s.%.3s]\n", entry->filename, entry->ext);
break;
default:
printf("File: [%.8s.%.3s]\n", entry->filename, entry->ext);
printf(" Modified: %04d-%02d-%02d %02d:%02d.%02d Start: [%04X] Size: %d\n",
1980 + (entry->modify_date >> 9), (entry->modify_date >> 5) & 0xF, entry->modify_date & 0x1F,
(entry->modify_time >> 11), (entry->modify_time >> 5) & 0x3F, entry->modify_time & 0x1F,
entry->starting_cluster, entry->file_size);
int main() {
FILE * in = fopen("test.img", "rb");
int i;
PartitionTable pt[4];
Fat16BootSector bs;
Fat16Entry entry;
fseek(in, 0x1BE, SEEK_SET); // go to partition table start
fread(pt, sizeof(PartitionTable), 4, in); // read all four entries
for(i=0; i<4; i++) {
if(pt[i].partition_type == 4 || pt[i].partition_type == 6 ||
pt[i].partition_type == 14) {
printf("FAT16 filesystem found from partition %d\n", i);
break;
if(i == 4) {
printf("No FAT16 filesystem found, exiting...\n");
return -1;
fseek(in, 512 * pt[i].start_sector, SEEK_SET);
fread(&bs, sizeof(Fat16BootSector), 1, in);
printf("Now at 0x%X, sector size %d, FAT size %d sectors, %d FATs\n\n",
ftell(in), bs.sector_size, bs.fat_size_sectors, bs.number_of_fats);
fseek(in, (bs.reserved_sectors-1 + bs.fat_size_sectors * bs.number_of_fats) *
bs.sector_size, SEEK_CUR);
for(i=0; i<bs.root_dir_entries; i++) {
fread(&entry, sizeof(entry), 1, in);
print_file_info(&entry);
printf("\nRoot directory read, now at 0x%X\n", ftell(in));
fclose(in);
return 0;
