[Moved]: Question about Components in Cadence
Shady Ahmed
Member level 5
I have a question in Cadence,
say for example that i created a component (op amps ) and i intend to use that component in another schematic, for instance : i'll place it 10 times, however i want to change a value of some parameters in that op amp for 1 op amp without affecting the other 9, is there another way to do so other than creating a separate symbol for each?
Re: Question about Components in Cadence
There are parameters called pPar which are exactly what you are after. But you will need to meddle with cdf and stuff. There are guides online that might be doing exactly what you're planning to do.
Thanks for the answer, I knew it had to be in cadence but needed a name for that feature, I'll look into it.
