me also I am working with this IC IR21362 but nothing at the output,I propose you first to post your circuit configuratio so we can judge for help but myself for IR21362 I get nothing https://www.edaboard.com/threads/354240/#post1515384
I received the required output, I applied positive pull up resister & one decoupling capacitor 0.1uF disc capacitor to enable pin & get the required output.
AN0843 VFD is working, but
giving me 230V at 58Hz between M1 & M2, 139V 8Khz between M2 & M3, & 140V 8Khz between M3 & M1
Driver IC, IR21362 getting slightly heat & getting short at com pin & LO3 pin of IC, Can any body analyze & explain where might be the problem or can any body share their experience while working on AN0843 VFD.
