jean12
Advanced Member level 2
Hello,Dear I connected the IR21362 as follows but I am not succeeding to output an signal from it;the configuration pins are connected as follows
Pin 8:FAULT:Not connected
pin9:ITRIP not connected
pin 10:EN-----------------VCC
Pin11:RCIN:resistor and capacitor added as indicated in the datasheet of the component
pin12:VSS------------------Gnd
pin13:COM-----------------Gnd
could you suggest how I may connected this component,it gives no signals(at least the LO may be obtained)but I don`t get them
Please help
Please help
