[Moved] problem faced during interfacing gsm with 8051
ashwija
Newbie level 1
hi...,
we r facing a problem while interfacing gsm wit 8051, we r able to interface gsm with pc n 8051 wit pc , but we are not able interface microcontroller wit gsm module..plz help us
here is our code
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
#include<at89x51.h>         // include at89x51 . h
#include<stdio.h>                    // include stdio . h
#include<stdlib.h>                          // include stdlib . h
unsigned char Command_CMGF[]="AT+CMGF=1\r";
                                    // AT+CMGF for selecting Text Mode
unsigned char SUB[]="0x1A";
//# define C  Ctrl^Z                                               // CTRL+Z for sedning SMS after the message has been entered
unsigned char Command_CMGS[]="AT+CMGS =+919590166616\r";
                                   // recepient mobile number
unsigned char Command_AT[]="AT\r";
unsigned char msg02[]="Hello!";
 void delay2(){
unsigned int i;
for(i=0;i<25000;i++);
void initialize_serialcommunication(){
TMOD = 0x20;
SCON = 0x50;
TH1  = 0xFD;
TL1  = 0xFD;
TR1  = 1;
TI = 1;
 void initialize_GSM_modem(){
 delay2();
puts(Command_AT);
delay2();
puts(Command_CMGF);
delay2();
puts(Command_CMGS);
delay2();
    puts(msg02);
delay2();
while(!TI);
 TI=0;
 SBUF= "^Z";
//SBUF=0X1A;
//SBUF=SUB;
 void main ()
 initialize_serialcommunication();
   initialize_GSM_modem();
while (1) {
Re: problem faced during interfacing gsm with 8051
what type of problem u r facing
better u can try ur code in proteus and thn u can chek in hardware
What part are you facing problem actually..?
This much is what I figured out:
You need to give Carriage Return and Line Feed after every UART tx, not just carriage return.
SBUF= "^Z";
The Ctrl+Z should not be a string, instead use the ASCII equivalent.
hai ashwija
you have to use Carriage return ASCII value 13 because of "\n"
check the port connections to which your gsm is interfaced.
better to verify the code using proteus.
try these changes.
1.msg02[]=msg02[]="Hello!\r";
2.After sending msg02 send 0x1a or equivalent decimal not a string or ^z
try these changes.
what is the meaning of double declaration of msg02[] ?
Working mikroC PRO Code attached.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
#include <reg51.h>
unsigned char Command_AT[3] = "AT";
unsigned char Command_CMGF[16] = "AT+CMGF=1";
unsigned char Command_CMGS[16] = "AT+CMGS=";
unsigned char mobileno[16] = "+919590166616";
unsigned char SMS0[] = "Hello!";
void Delay_ms(unsigned int msec);
void UART_Init();
void SendSMS();
void UART_Write(unsigned char uartData);
void UART_Write_Text(unsigned char *uartData);
void Delay_ms(unsigned int msec){
        unsigned int i;
        for(i = 0; i < (5 * msec); i++);
void UART_Init(){
        P3   = 0x03;
        TMOD = 0x20;
        SCON = 0x50;
        TH1  = 0xFD;
        TR1  = 1;
        EA   = 1;
      ES   = 1;
void SendSMS(){
        UART_Write_Text(Command_AT);
        UART_Write(0x0D);
        UART_Write(0x0A);
        Delay_ms(4000);
        UART_Write_Text(Command_CMGF);
        UART_Write(0x0D);
        UART_Write(0x0A);
        Delay_ms(4000);
        UART_Write_Text(Command_CMGS);
        UART_Write(0x22);
        UART_Write_Text(mobileno);
        UART_Write(0x22);
    UART_Write(0x0D);
        UART_Write(0x0A);
        Delay_ms(8000);
    UART_Write_Text(SMS0);
    UART_Write(0x0D);
        UART_Write(0x1A);
        UART_Write(0x0D);
        Delay_ms(8000);
void UART_Write(unsigned char uartData){
        SBUF = uartData;
        while(TI == 0);
        TI = 0;
void UART_Write_Text(unsigned char *uartData){
        while(*uartData)UART_Write(*uartData++);
void main (){
    UART_Init();
      Delay_ms(4000);
        while (1){
                    SendSMS();
  • GSM 8051.rar
