[MOVED] PMOS differential amplifiers
silversgleaming
Newbie level 3
Newbie level 3
Singapore, Singapore, Singapore
I am a newbie here.
I am supposed to design an op-amp with gain of at least 20dB using aim SPICE.
I have the following differential amplifier
with small differential gain as shown
How do I improve the gain by modifying or adding some elements to the amplifier?
*All transistors must be pmos transistors.
Schematics are highly appreciated.
Thank you!
Franklin
hi,
You can simply use CS pair to improve the gain which is connected to ech outputs of differential pair...
Still you need more gain means, use cascode pair.........
Thanks
hi,
Thanks
So CS amplifier can be added to vout1 and vout2?
does using cascode pair mean adding 2 pmos transistors below X3 and X4?
yes ofcourse, CS pair can be added to each outputs....
You can use 2 PMOS pairs as cascode load but it cause some voltage headroom problem....
Still You can get high gain.... and
What is your operating frequency...?
Thanks...
Thanks...
Do you have the schematics? (without resistors)
The operating freq is 1Hz.
Thanks.
Thanks.
operating frequency 1Hz.. is it...? May i know the purpose of getting high gain?
and Schematic ..... just add another one pair of P-Mos es under the X3 and X4 moses.. But you need to give a biasing voltage for this pair...
Anyway.... using PMOS and Nmos pair gives good results.... Try the above... and Make sure your operating frequency..
Thanks......
