JustinN
Newbie level 2
I'm a complete newb in the area although I have saved a number of people's iPhone logic boards after being submerged in saltwater a few times.
I have a deer feeder we use in the our property to feed the local deer. I went to refeed and do regular maintenance and I noticed the weather protection piece was filled with water (no telling how long). To my suprise the battery connections were a lil bad but after a little tweaking it worked fine. All the buttons worked and i was able to reprogram the timers. I walked out a week later and noticed the timer had gone off. It showed the time on the lcd, but the program button wouldnt work while the + and _ as well as the test button would work. I assume the water level didnt go higher than the program button.
I took it apart and found corrosion on the back of test button. I attempted to clean it with isopropyl along with a toothbrush and I had no results. While being disconnected from the battery the lcd still showerd power but i assume the capacitor just kept holding the charge. I removed the circuit board from the panel order to see if there was corrision on the front. I had to remove the brown board (pins connected to lcd) in order to get a screw out and pull it from the panel. Once i did this the lcd shut off. I cleaned the corosion, placed it back together and i can not get anything to show on the LCD. Much less get the buttons to work like the test feature.
Any Ideas?
Any help would be appreciated.
Any Ideas?
