Usually you are very flexible in dimensions. You can build a small 22uH coil and you can build a big 22uH coil.but it would take very small dimensions
... i tried using inductor calc but it would take very small dimensions to make such coil, any alternatives ?
First you decide the frequency; next you calculate the inductor value. It may come only 3-4 turns of 1mm dia Cu wire wound on a plastic former of 4-5mm dia.
I know it is difficult to get an exact value this way. But you can squeeze or stretch the coil little bit and adjust the inductance. It is not difficult to make a 22nH inductor.
I know it is common to suffer from information overload; the idea is that you should also learn some basics on the way- it should not be a soldering job only. That you are here suggests that you want to learn the basics.
alright so i'll have to take measurements of wire diameter and add it to coil's diameter to get the total diameter into the equationWire diameter does not matter - the inductance will be same.
We use thicker wire for mechanical strength- the coil is self-supporting and if it moves or shakes or vibrates, the inductance will change- even a little change will cause your transmission to shift frequency.
Usually the diameter of the former is added to the diameter of the wire to get the diameter of the solenoid. In other words, the diameter of the solenoid is measured from the centre of the wire.
Similar considerations are there for the length of the solenoid. Physical length of the coil is taken from the centre of the wire. We usually do not bother much.
Once you get an idea, you make the coil (and measure with a meter) then fix it and squeeze or stretch the length a bit so that the frequency comes in the range.
im going to connect components in dead bug style is it ok to use little glue to stick bits of copper clad into the board ?Hi,
Fixing the coil:
I don't recommend to use two compound glue..because it is highly dielectric...and worst of all it changes dielectric value during curing.
This dielectric between the winding will influence overall resonant frequency.
Maybe hot melt solutions are better.
i want to make a small transmitter with a small range of 10-20 meter for our college lecture hall and use an old radio as a receiver and connect it to an amplifier, it might sound much but i dont have enough capabilities in my country to make something better, i tried looking for other transmitter only few i found that their components are in my country, some others are too complex :SLike I said on the other forum (I can't remember which one) an ordinary FM transmitter usually operates on the FM broadcast band which is from 88MHz to 108MHz and uses a coil that is usually 100nH made with 5 to 9 turns of wire on a 3mm former. The value of this coil is much lower so the frequency will be much higher. Do you have a radio to receive it?
The value for C4, C6, C7 and C8 are wrong.
This transmitter is so simple that it will have serious problems.
I wonder what input you made .. and what calculator you used: I didn´t find "inductor calc"
It seems to be a resonant circuit. About 8.8MHz if my calculation is correct.
But it is no very special device. It should be available almost all over the world.
Please try to give complete and more exact informations. Maybe documents, links, your input values and so on .. in a way that we are able to reproduce your trial.
i want to make a small transmitter with a small range of 10-20 meter for our college lecture hall and use an old radio as a receiver and connect it to an amplifier, it might sound much but i dont have enough capabilities in my country to make something better...
