[Moved] interfacing Glcd Qc12864b with pic
goldfinger2
Newbie level 5
egypt
Please i cant connect this glcd. Qc 12864b. with pic 18f4550 using micro c. Compiler because there is no lib for it and has adiffrent pinout, can any one help.
Re: interfacing Glcd Qc12864b with pic
Do you have the devices datasheet?
If so, upload it as an attachment or post a link to a download site.
BigDog
Thanks for fast replay
Here i attached the datasheet of it
  • QC12864B.pdf
According to the datasheet of your GLCD, the device utilizes an ST7920 controller chipset instead of the KS108 compatible chipset as required by the MikroC GLCD library.
Therefore you'll need to either utilize another GLCD library which supports the ST7920 controller chipset or write your own routines specifically for your device.
The following MikroE forum posts seem to indicate the ST7920 is not compatible with the MikroC GLCD library:
Graphic LCD with ST7920
GLCD WITH ST7920 CONTROLLER
BigDog
