[Moved]: How to keep an Id (drain current) in CADENCE MOS characterization
nabarun2015
Newbie level 1
[Moved]: How to keep Id(drain current ) in CADENCE MOS charactarization
What will be the testbench circuit to get the curve of Gm vs Overdrive voltage of MOs charactarization. I mean I want to get the curve of Gm vs Voverdrive while keeping Id(drain current) constant in Cadence .What are the steps to simulate that in Cadence virtuoso and spectre ? Please reply asap.
Re: How to keep Id(drain current) constant in CADENCE MOS charactarization
See pp. 4 & 8 of this PDF: View attachment gm-Id-example_curves.pdf
Instead of connecting the drain to the gate, connect it via a constant-current source (idc from analogLib) to the pos. terminal of a voltage source (vdc) to GND.
Re: How to keep Id(drain current ) in CADENCE MOS charactarization
Keeping the drain current would appear simple enough.
But if this fails for you, look into how the models are
architected. Some forms of subcircuit modeling (as are
common in RF) put the MOSFET below a subcircuit layer
which isn't named the same as what you see on the
schematic, and thus what would naturally be the "keep"
name of the device*port. You may fail to get the current
at all, or you may get a current which has the MOSFET
but not any "helper" devices' contribution to the net drain
current (e.g. a veriloga "kink" feature added on to model
drain nonlinearities the base model can't). In this case you
either have to educate the PDK (good luck) or interpose
some benign sense element between the drain and elsewhere
(I prefer the presistor as it is always LVS-neutral). Keep
that device's current instead and you have what you need.
