This is my First HFSS project. I already got some results however not sure if it is right. And also some questions need answers. Thanks for reading my question and help me
The following is my model:
As you can see the outside large cube is the air-filled cavity, and I set it as Radiation Boundary.
The pink part is the 0.3mm thickness atenna, and I set it as Copper and Perfect E.
The thin cube right above the atenna is just copper with 0.3mm thickness, and I set it as Perfect E.
The little bit larger thin cube right under the atenna and the copper is the FR4_epoxy with 1.6mm thickness.
There is also another copper with 0.3mm thickness, and I set it as Perfect E.
There are two lumped port on the two sides of the atenna.
By runing this model, I got some results as followingg:
#1 XY_Plot_S(1,1)
#2 Radiation_Pattern
#3 Smith_Chart
#4 3D_Polar_Plot
I am not sure if my model and my results are right and make sence. Is there any suggestion or tip?
I also have some questions as following:
Q1: Should I use two lumped ports? If there is actually only 1 port connect my antena on the matter. I thought I need to set at least two ports as input and output.
Q2: Should I draw additional rectangles as the plane of ports? Or I can simply use the side face of my antena as the port? If I need draw the additional rectangle as the plane of ports, what is the right size of the plane?
Hope I can have some helps from here[ Or you can just reply your suggestions here.
