I'd think in this configuration (power supply interference source in the input control loop),
PSRR is the same as gain (no rejection at all), i.e. - in first order approximation, neglecting the output impedances of the transistors -
PSRR = gain ≈ gm1*R1 * gm2*R2
If you move the power supply interference source outside of the input control loop, PSRR ≈ gm2*R2 ,
- s. the right side of the PDF: View attachment PSRR.pdf
