motion detector, toothPIC
Twins_sasa
Newbie level 5
Newbie level 5
I had bought a motion detector(Paradox DG55). It has 6 pins: N.C, COM, +i/p. -i/p, 2 pins for anti-tamper switch.
Some info form the data sheet:
Alarm output: Form A relay 100mA/28Vdc, N.C (optional form C relay 500mA/30Vdc, N.C/N.O)
Anti-tamper switch: 150mA/28Vdc, N.C
Voltage input:: +12Vdc
Normally motion detector is connected to alarm. But in my project, my idea is to connect the output of this motion detector to a ToothPIC microcontroller.
So when motion is detected, the motion detector will send an output voltage which is connected to input pin of ToothPIC. Then the ToothPIC will send an signal to a user PDA.
I'm not sure whether this idea is correct or not.
And i want to measure the output voltage of the motion detector(because the input voltage of ToothPIC is only 5-10Vdc).
My prob is i don't know how to connect the motion detector pins(NC, COM, etc) with the ToothPIC.
Can anyone teach me about that?? explain in detail which pin to connect to what.
High appreciation to all of u guys reply and help.
Thanks very much.
i guess it don't have N.O because in the data sheet is stated "N.O optional": Form A relay 100mA/28Vdc, N.C (optional form C relay 500mA/30Vdc, N.C/N.O) , am i right???
Twins_sasa
Newbie level 5
Newbie level 5
from the power supply, i connect the +12Vdc to +i/p, then ground should go to -i/p or COM?
since the sensor only have N.C and COM, i/m wondering does it mean when motion is detected, the N.C relay switch will open and no output voltage will trigger the PIC. Is my concept correct?
pls advise. thanks very much.
IanP
Advanced Member level 7
West Coast
In your case you will be using 4 connections: +12V (+i/p), 0V (-i/p), COM and N/C.
Don't worry about anti-tamper, although you ca conet it in series with COM or N/C contact, so if someone tries to open the enclosure it will also set-off an alarm, but it is optional ..
On the ToothPIC select which input would you like to connect to the sensor: I guess you can use any of AN0-AN11 inputs and configure them as Digital Inputs.
So run two wires from the sensor to the ToothPIC, connect the COM wire to ToothPICs 0V and the N/C to the selectet AN input (you may need to connect a pullup resistor between this input and +Vcc; a 4.7-10kΩ resistor will be a good choice). Remember, that you will be working with NEGATIVE logic, what means that the active state will be when the contact is open .. thats all ..
Regards,
IanP
Twins_sasa
Newbie level 5
Newbie level 5
ya, i followed your way and the sensor can work already.
But when motion is detected, the output of the sensor is very small(<1V), unstable, discontinous and only trigger for around 3 seconds. It's not as the expected +5V. After 3 seconds, it wil back to ready state(0V) again.
This is not enough to trigger the ToothPIC to work properly.
I plan to have a OP-AMP to boost the voltage. But how about the problem of discontinous output?
Any idea or better solution for that?
thank q very much for your advise.
IanP
West Coast
You can fix the issue of the output response by adding a monostable 555 timer, and set it up to generate 1, .., 3, .. 5 sec (or whatever) pulse ..
This timer can be trigged by the signal from the motoin detector through a transistor driver or a comparator, in both cases signal of 1V from the motion detector will be sufficient ..
(see pictures below)
For more on 555 in monostable configuration goto: **broken link removed**
Regards,
IanP
Twins_sasa
Newbie level 5
Newbie level 5
sorry sorry, i made a mistake.
I got the "unexpected output" previously is because i connected wrongly some wiring.
Ya, the output is +5V when moton is detected. It is stable but it only last for 3 seconds, then the sensor will go back to ready state (0V).
How to make the output voltage last longer so that the ToothPIC can have enough time to perform its task? (last 10seconds will be good enough).
Appreciation and Thanks for helping.
IanP
West Coast
In this situation use 555 timer in the monostable configuration (see circuit below) ..
For 10s pulse: R=100kΩ, C=100µF ( or R=1MΩ, C=10µF , .. )
To make it working correctly you will need to reverse the phase of the signal from the motion detector; add transistor driver described in the previous post and use 10kΩ resistors (between sensor and base, and collector and +5V) ..
C between 5 and GND = 10nF
R between 2 and +5V = 10kΩ
Input C = 100nF ..
Regards,
IanP
Twins_sasa
Newbie level 5
Newbie level 5
Ya, i had tested it.
But the transistor driver is convert the input(+5V) to 0V (or 0V to +5V). And it's not convert from +ve to -ve phase. So, the 555 timer cannot be trigger. Correct?
What do you think about this issue?
Thank you.
IanP
West Coast
Bear in mind that 555 is trigged at the falling edge of the input signal, and the motion sensor produced 5V when active ..
So, the signal from the motion detector has to be inverted, and this can be done by a single transistor or any CMOS/TTL inverter (NOT gate) ..
Regards,
IanP
Twins_sasa
Newbie level 5
Newbie level 5
Wao! i got it!
I follow your suggestion to set up. But the invertion of motion detector output, i didnt use the transistor driver. Instead, i use a 741 Op-Amp and set it as a inverter circuit.
Then for the 555 monostable timer, i did follow your diagram. But i take out the 10kΩ resistor between 2 and +5V. This is because i cant figure out why we need to connect +5V to pin2 since the desire input to trigger the 555 timer should be the op-amp inverter output.
And i got the result i want already.
Thank you very much IanP, you did help me a lot.
