Jester
Full Member level 6
I'm thinking of using a 2N7002 FET in a circuit where the gate voltage could exceed the +/-20V VGS rating of the above mentioned FET, however the schematic symbol of this part shows internal back-to-back Zeners between the gate and source AND there will be a 10k series resistor between the gate drive signal and the actual gate.
I don't see a rating for the internal Zeners, other than VGS = +/-20V in the MAXIMUM RATINGS
The gate signal, will typically be < 10V, however there could be at times a repetitive 50V peak signal (see below), this signal will be current limited by a 10k resistor.
Will the internal back-to-back Zeners protect the FET or do I need to include additional protection?
Link to data sheet: https://www.onsemi.com/pub_link/Collateral/2N7002W-D.PDF
