monte carlo simulation,corner simulation,PVT simulation
present
Member level 2
Anybody can tell me the difference between "monte carlo simulation", "corner simulation" and "PVT simulation"? Pls tell me what parameters they are varying?
Thanks.
yibinhsieh
Full Member level 4
1. monte carlo simulation is used to simulate the mismatch effect to the circuits.
Usually, the width, VT, R, and C are varied to see what happen to your circuits.
2. corner simulation means process variation simulation. It's part of PVT.
3. PVT simulation: P stands for process, V stands for voltage and T stands for temperature.
Proces corner:
TT, FF, SS, FS, SF for MOS
max, min, typ for passive devices like C&R&L.
temperature: room, high and low.
Yibin.
    present
present
Member level 2
For corner simulation and PVT simulation, I think I know them already.
For monte carlo simulation, I was told it need the monte carlo model of the process.
I want to know that:
1. is monte carlo simulation for MOS transistors only? not applicable for bipolar transistors?
2. if I don't have the monte carlo model, what variables I should set? for the NMOS, PMOS, capacitor, resistor, ...?
the width, VT is for MOS, right?
R and C will be varied same as corner simulation, is it?
Proces corner:
Yibin.
present
Member level 2
If I don't have the monte carlo model file, what are the variables I should set?
Thanks.
luojiexiaojun
Junior Member level 2
Thanks.
vth tox rsh in your lib file
wuwoze
Junior Member level 1
You have the TSMC 0.18 model card? It has Monte Carlo.
keoiuser
Member level 2
Monte Carlo simu may be used for any circuit that can contain either MOS & bipolar.
If you don't have model you should vary the resistor, capacitor VTH ..
For corner simu, there is a variation of the transistor model & a variation of temperature and power supply, but in Monte Carlo you must fix your temperature & power supply and vary only the model of transistor.
