Yes, but only if you connect it to one of the variable outputs and set the voltage to 12V! Less voltage = no lights, more voltage = smoke.sweet, so the LED strip will work regardless of needing to add a 12V regulator
The USB connector must ONLY be wired to 5V. Connect the '-' pin of the USB connector to ground and the '+' pin to the fuse holder. The other side of the fuse holder goes to the fixed 5V outputAlso the USB connectors must be attached to the +1.25 - 15V with the use of a 600mA fuse. So those two are taken care off.
small fan to the heatsink.
I was thinking about adding a small fan (30mmX30mmX10mm) but it might reduce the overall voltage it supplies to the other outputs.
Now for the volt meter, do i connect it to the same 5v output as the USB connectors is that what you are trying to say? Or just the +1.25-15V but just cahnge it to a fixed 5V output. Also what about the blue,yellow and green wires, where do i connect those to?.Also what do i do with the shunt.
