Modelsim do not provide output for module with delay more then 1ns
I'm trying to delay ripple clock where output of D-flipflop will go through a delay cell before reaching another D-flipflop. If I use delay cell with 1ns delay, Modelsim simulate it fine.
Re: Modelsim do not provide output for module with delay more then 1ns
Why pulse duration have to be larger then Delay ? suppose I want to give a 1ns pule at one node and want to send the same pulse at different node with with 2n delay, it is physically possible to design a 2ns delay block manually. Now I wanna use that block as module to simulate Verilog, what should I do ?
The continuous assign statement and gate primitives simulate using an inertial delay model. That means the output cannot change faster than the input. You want a transport delay model. For that you need to use specify block path delays, or the non-blocking assignment. Specify blocks can get quite involved, so I'll just show the non-blocking assignment version:
Code Verilog - [expand]
`timescale1ns/10psmodule CLKDLY2X1(inputwire A,outputreg Z);always@A Z <=#2 A;endmodule
