modelsim command line arguments
eng.amr2009
Junior Member level 3
Egypt
Hi there,
I was developing a TCL script for simulation with modelsim. The TCL script accepts some command line arguments like
[B]simconfig.tcl[/B] -coverage <value1> -toplevel <value2> -tc <value3>
When I tried to run the script via tclsh under linux, it works perfect. As I actually need it for modelsim simulation, I tried to run it from modelsim console via do like
do simconfig.tcl -coverage <value1> -toplevel <value2> -tc <value3>
The script did not work. After some debugging I found out that modelsim does not pass the arguments to the tcl script. To make sure a created another script sim.do and ran it using do with same arguments passed above, I echoed the $argv, it did not include the passed argument variable !!!!
I do not need to use $1, $2 as this reduces script comparability.
Any ideas ?
Thanks in advance.
argv contains the arguments used when invoking modelsim/questa. You must use $1-$9 to get the macro arguments. Consider writing your script as a Tcl procedure , and then call the tcl procedure.
