ZincBear
Member level 2
transmission line capacitor modeling
Hi there!
I am using some pretty fat transmission lines as capacitors for an input matching network. I have previously used ceramic caps, which are accurate, but are extremely sensitive to temperature, and have no room for tuning.
In a crude manner, we can simply use C=ε0εrA/D, and use an area that would give us the respective capacitance. However, this is not accurate, as the patch becomes wider(see word document). This is because the FET would see the wide patch as 2 open circuit stubs instead.... so its capacitance will deviate from the actual calculated figure from the above formula.
Has anyone have got a good idea on modelling such a fat transmission line as a capacitor?....
Thank you so very much for your help!
Hi there!
