DwigB
Newbie level 1
I have done some exhausted search for ASM code for implementing MODBUS CRC calculation. I finally gave up and developed this simple code that works.
Once this is done the string of bytes to be transmitted are processed by calling the routine below.
Code ASM - [expand] 1 2 3 4 5 6 ; The registrars where the CRC results will reside have to be set to 0xFFFF. CRC16_Init: ; Reset CRC Registar MOV D_CRC16_Hi, #0FFh MOV D_CRC16_Lo,#0FFh RET
Code ASM - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 CRC16_AddCalc: ; Calc CRC PUSH R_0 ; Save Reg 0 PUSH Acc ; Save Acc MOV R0,#08h ; 8 Bits XRL D_CRC16_Lo,A ; Lo ^=Data L?P1: CLR C ; Clear Carry MOV A,D_CRC16_Hi ; D_CRC << 1 RRC A ; Shift Left MOV D_CRC16_Hi,A ; Store Back MOV A,D_CRC16_Lo ; Get Hi Byte RRC A ; Shift Left MOV D_CRC16_Lo,A ; Store Back JNC L?P2 ; Skip if Bit 15 wasn't set XRL D_CRC16_Hi,#0A0h ; XOR in Polynomial High XRL D_CRC16_Lo,#01h ; XOR in Polynomial Lo L?P2: DJNZ R0,L?P1 POP Acc POP R_0 RET
