Jigar 4 Electronics
Full Member level 5
- Joined
- Apr 28, 2011
- Messages
- 312
- Helped
- 40
- Reputation
- 82
- Reaction score
- 38
- Trophy points
- 1,318
- Location
- Hamilton, ON, Canada
- Activity points
- 3,368
Hello,
I am trying to interface MMA8451Q Accelerometer with My stellaris launchpad LM4F120H5QR, it uses I2C interfacing.
My code is correct because it works with the other sensor which uses the I2C interfacing.
But that same code is not working with MMa8451Q.
Is there anyone who has an experience to work with MMA8451Q ??
(**broken link removed**)
If yes then please suggest me some steps about how to communicate with it successfully.
I've posted the same problem on the website of TI also.. still the problem is unsolved... any experience/suggestion will help me.
https://e2e.ti.com/support/microcontr...aspx?pi74263=2
Thanks for your time.
I think I am very near to get the solution.
I've refer the datasheet one more time.
Here is the what specs. for SCL the datasheet is indicating :
My mistake was - I was trying it with 100kHz and 400kHz with 4.7k pull up.
In my accelerometer board schematic (shown below) it has shown that Cb (Bypass capacitor) is not there! (AM I WRONG while saying this?)
Pin 2 : has a Bypass capacitor of 0.1uF but is it my Cb ???
Cb is a Total capacitance of one bus line in pF which could be 20pF, 40pF or 400pF.
So now I need some experienced suggestion that what capacitor I should connect where & which SCL frequency I should use?
For datasheet of MMA8451Q, you can have it from here : https://www.nex-robotics.com/images/downloads/MMA8451Q.pdf
PLEASE help me out with this.
