mixing blocking and nonblocking statements
rocking_vlsi
Member level 5
Member level 5
sorry if it is repeating.
people does mix of both blocking and non-blocking statements.
as
always@(posedge(clk))
begin
temp_var=a&b;
if(condition)
temp_reg<=temp_var;
end
For simulation and synthesis how does it differ?
Definitely a race condition in simulation if temp_var is read on a p(osedge clk) in another block.
do it like this to separate the combinational and sequential code
assign temp_var = a & b;
begin
if(condition)
temp_reg<=temp_var;
end
What tariq said is conventional method, used widely. The point is if they are mixed: Now since order of execution for same activity constraint always block is random, in this case sometimes you may get race condition if blocks using temp_var are executed earlier than this. So if you are really forced to mix, make sure that temp_var is nor used elsewhere at posedge clk.
Dave, correct me if i am wrong. Even if temp_var is read on posedge clk in another always block in a non-blocking assignment, the old value of temp_var will be sampled rather than the new one. For example
//first always block
begin
temp_var=a&b;
if(condition)
temp_reg<=temp_var;
end
//second always block
begin
another_temp_reg<=temp_var;
end
If (condition) is false, then there is only a blocking assignment to temp_var. The sampled value of temp_var has a race.
