Minimum required current of zener diode
eem2am
Banned
hello,
do you know what is the minimum "holding" current of the 15V zener here....
i would presume that a certain minimum current must flow in order for the zener to actually regulate to its zener voltage?
That zener diode has its voltage spec'd when it has a current of 5mA. Its regulation is 13.3 times worse and its voltage is lower (but they don't show how much lower) when its current is only 1mA.
A zener diode regulates better when its current is higher.
