T
treez
Hello,
We are doing a 1V5, 160A power supply as in the attached pdf.
We are using Vicor Power modules.
We must use the absolute minimum capacitance (the purple ringed capacitors) . How can we assess what is the minimum capacitance that we can use from a transient response viewpoint?…I believe the app notes don’t give enough data and we would actually need to build it and do transient response tests…do you agree?
After all, there is no data on the crossover frequency of the P024T048 module with “x” amount of output capacitance and therefore we must build and test.?
P024T048T12AL power module
http://www.vicorpower.com/products?productType=cfg&productKey=P024T048T12AL
VTM48ET020T080A00 …fixed ratio voltage converter
http://www.vicorpower.com/products?productType=cfg&productKey=VTM48ET020T080A00
And this is related to the above....concerning "Feedback loop bandwidth increase of cascaded SMPS converters?"
Figure 1, Page 2 of the P024T048T12L power module datasheet (below) shows a setup involving a SMPS which comprises a regulation stage followed by an “electronic transformer” voltage down converter stage. Page 2 of this datasheet states that this setup gives “bandwidth and speed advantage“
Why is this?
Since when did cascading a regulated SMPS with a fixed conversion ratio voltage converter mean you can get faster feedback loop bandwidth?
P024T048T12AL power module datasheet
http://cdn.vicorpower.com/documents/datasheets/24V_48V_120W_PRM.pdf
VTM48ET020T080A00 …fixed ratio voltage converter datasheet
http://cdn.vicorpower.com/documents/datasheets/VTM48E_020_080A00.pdf
Why is this?
