[SOLVED] MIKRO C LCD ERROR PIC 16f688
antriksh
Newbie level 6
Newbie level 6
i have used a lcd to infce with pic 16f688 . but after a perticular code if add any thing it will effect on lcd and chage there orentation of text.
code as give below :
// LCD module connections
sbit LCD_RS at RC5_bit;
sbit LCD_EN at RC2_bit;
sbit LCD_D4 at RC1_bit;
sbit LCD_D5 at RC0_bit;
sbit LCD_D6 at RA2_bit;
sbit LCD_D7 at RA1_bit;
sbit LCD_RS_Direction at TRISC5_bit;
sbit LCD_EN_Direction at TRISC2_bit;
sbit LCD_D4_Direction at TRISC1_bit;
sbit LCD_D5_Direction at TRISC0_bit;
sbit LCD_D6_Direction at TRISA2_bit;
sbit LCD_D7_Direction at TRISA1_bit;
// End LCD module connections
unsigned int displaycount,OPVOL,BATTVOL,CTVOL = 0 ;
unsigned char count,flag = 0 ;
char *adc= "00.0";
char *adc1= "000";
void Display_adc(unsigned int adc2write){
  adc[0] = (adc2write/100) + 48;      // Extract hundreds digit
  adc[1] = (adc2write/10)%10 + 48;    // Extract tens digit
  adc[3] =  adc2write%10     + 48;      // Extract ones digit
void Display2_adc(unsigned int adc12write){
  adc1[0] = (adc12write/100) + 48;      // Extract hundreds digit
  adc1[1] = (adc12write/10)%10 + 48;    // Extract tens digit
  adc1[2] =  adc12write%10     + 48;      // Extract ones digit
void InitTimer0(){
  OPTION_REG           = 0x87;
  TMR0                 = 100;
  INTCON               = 0xA0;
 void Interrupt()  // 20 ms timer intruppt
  if (TMR0IF_bit)
    TMR0IF_bit         = 0;
    TMR0 = 100;
    displaycount++;
    count++;
void main() {
TRISC   = 0b11111111;      // Make Rc0 input
TRISA   = 0b11111111;      // Make RA0 input
PORTA = 0X00 ;
ANSEL   = 0b10001001;
//ADCON1 = 0x00;
CMCON0 = 0x07 ; // Disbale comparators
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // CLEAR display
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
  ADC_Init();
  InitTimer0();
  Lcd_Cmd(_LCD_CLEAR);               // Clear display
while(1)
        OPVOL = ADC_Read(3); // Get outpt voltage
        CTVOL = ADC_Read(0); // Get load current
        BATTVOL = ADC_Read(7); // Get batt voltage
  if( displaycount == 1 || displaycount == 25 || displaycount == 50 || displaycount == 99)   // output voltage display
        if (RC4_bit == 1)
          Lcd_out(1,1,"  LOAD ON MAINS ");
        else
         Lcd_out(1,1,"  LOAD ON BATT  " );
         Lcd_out(2,1,"OUTPUT VAC=    V");
         Display2_adc(OPVOL);
         Lcd_out(2,12,adc1);
if(displaycount == 100 || displaycount == 125 || displaycount == 150 || displaycount == 199)   // load current display
         Lcd_out(1,1,"  LOAD CURRENT   ");
         Lcd_out(2,1,"  AMP =    A    ");
         Display_adc(CTVOL);
         Lcd_Out(2,8,adc);
if(displaycount == 202 || displaycount == 225 || displaycount == 250 || displaycount == 299)   // batt volt display
         Lcd_out(1,1," BATTERY VOLTAGE" );
         Lcd_out(2,1," VDC =    V     ");
         Display_adc(BATTVOL);
         Lcd_Out(2,7,adc);
if(displaycount >= 300)
     displaycount = 0;
while(BATTVOL >= 600)  // batt check
    Lcd_out(1,1,"   LOW BATTERY  ");
    Lcd_out(2,1,"RECHARGE BATTERY");
}  // while end
if i add this in main... LCD TEXT CHAGE AUTOMATICALY
while (OPVOL >= 600)  // batt check
becuase idont want any thing to disply on lcd at this point of time ... it is working but in normal case some text chnge on lcd . and i am noticing in only this bit code RAM is 78% full alredy
hello,
Post the result of compilation see the window "messages"
copy all as text and post it.
I agree with Zuisti, probably problem of RAM BANK
you can pass over by using message in ROM space instead of RAM
or use EEPROM !!
declara a table in RAM
and use this:
// declaration
char CRam1[18];
// --- Copie le texte depuis ROM vers RAM
void strConstRamCpy(unsigned char *dest, const code char *source) {
  while (*source)*dest++ = *source++ ;
  *dest = 0 ;    // terminateur
//in your main programm replace by
strConstRamCpy(CRam1,"  LOAD ON MAINS ");
 Lcd_out(1,1,CRam1);
strConstRamCpy(CRam1,"  LOAD ON BATT  " );
Lcd_out(1,1,CRam1);
 strConstRamCpy(CRam1,"OUTPUT VAC=    V");
Lcd_out(2,1,CRam1);
and check again what is the remaining amount of RAM .
hello,
or use EEPROM !!
and use this:
// declaration
char CRam1[18];
 Lcd_out(1,1,CRam1);
Lcd_out(1,1,CRam1);
Lcd_out(2,1,CRam1);
thanks i have used the same..
