Jul 9, 2012 #1 K krimoni Newbie level 6 Joined Sep 14, 2007 Messages 11 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,345 Why at higher frequencies the components size gets smaller?
Jul 9, 2012 #2 G godfreyl Advanced Member level 5 Joined Apr 18, 2012 Messages 1,974 Helped 632 Reputation 1,266 Reaction score 621 Trophy points 1,393 Activity points 12,772 The wavelength is smaller at higher frequencies.
Jul 9, 2012 #3 vcoltech Member level 3 Joined Aug 27, 2010 Messages 58 Helped 17 Reputation 34 Reaction score 16 Trophy points 1,288 Location Vietnam UET Activity points 1,585 Ok, Hi friends component size small because it's determine by wavelength. example, antenna of 900 Mhz length than 1800 Mhz, by length of antenna determine by wavelength/4. same with orther component.
Jul 9, 2012 #4 tony_lth Advanced Member level 5 Joined Jul 28, 2010 Messages 2,088 Helped 377 Reputation 756 Reaction score 368 Trophy points 1,363 Location Beijing Activity points 12,641 And, higher freq should have less parasitic parameters. So it is required to make small ic in package. - - - Updated - - - And, higher freq should have less parasitic parameters. So it is required to make small ic in package.
