Microstrip to coplanar transition
rainer
Member level 1
new york
I need to design an X band transition between microstrip and a grounded coplanar on a RO6002 substrate.
Have someone a suggestion or an example to share with me?
Thank's in advance
Manjunatha_hv
Advanced Member level 3
INDIA
Hello,
Here are the couple of Pictures how you can do Ustripline to CPW line transition...
---manju---
rainer
Member level 1
new york
Have you ever tried to design such structure starting from your proposal?
If yes, which were the results?
Have you ever tried a tapered solution?
Thank's
red-sun
Newbie level 6
do you have a book introducing such a problem? thanks
rainer
Member level 1
new york
You have said:
"This may help you
Abhishekabs "
What can help me?
I don't understand!
Added after 1 minutes:
Sorry there was a problem with the browser, so I wasn't abel to see the attached file.
Thank you.
