microstrip patch antenna feed
amntt
Full Member level 1
how to find best place for discrete port such az attached picture ? (it is picture of cst tutorial )
how i can understand that such patch antenna resonance at 2.2 ghz?
if i want to feed like second picture with wave guide port how i can find matched case
To answer your first and third questions, I would recommend doing a parametric sweep on the distance between the feed point and the edge of the patch. I'm not familiar with CST, but the best point is of course where the port impedance matches your system impedance (50 Ohms?). Alternatively, if you have the scattering parameters, you want the point which gives you the lowest S11.
For an analytical solution to all of your questions, I would recommend Balanis' antenna book.
Reactions: amntt
    amntt
