Microcontroller Relay Control
farfary52
Newbie level 3
hi
i want use this project for 8 relay (portb0-7) how can change source code for 8 relay ? please help me .:cry:
Please specify the microcontroller you intend on incorporating into your project.
It appears you are referring to a PIC variant, but which one exactly?
Also post any source code, using CODE or SYNTAX tags, you may already have written.
BigDog
  • SMS_remote_control_ericsson_module.zip
Are the relays controlled from PC? I don't know asm much. I can do a 8 relay project using PIC microcontroller. What are k7-k14 in the circuit?
hi
thank you for respond
1-What are k7-k14 in the circuit?
k7-k14 input from every sensors . but i want used k7-k14 for output port (relay control) instead d2-d5 port .
2-Are the relays controlled from PC?
no. i want control from gsm majol (gm-47) by sms.
3-I can do a 8 relay project using PIC microcontroller.
please help me . no problem you can used every microcontroller.
