swakit
Junior Member level 1
I have designed a VHDL code for fuzzy logic microcontroller. Code is working fine and simulation results are as expected. I am trying to burn the same code on xilinx spartan3 kit that i mentioned. I am using xilinx ise 9.2i for code simulation and testing. And iMPACT to burn the code into xilinx over a jtag link. I have successfully implemented other combinational as well as sequential units(with clock) on FPGA so it can be assumed that the method i am following is correct.
Now, when i burn the code of my microcontroller i get that message that programming is successful and done LED glows. But I am not getting the output. I am new in the field of FPGAs so I am unable to find way out. My microcontroller has quite a few of memory files as i need to maintain databases for fuzzy logic operation. And i think memory can be the possible reason of some error.
Is there any different method for configuring memory on FPGA or it is done just like other units?
Or is there any method by which i can debug working of my microcontroller when burnt in FPGA?
If you can help with anything it would be greatly appriciated!!
Please help sooner as my submission date is nearing
thanks a lot for reading all this
expecting a reply
expecting a reply
