Microcontroller Based Digital Pannel Meter
sameerr11
Junior Member level 1
lcd panel meter microcontroller
hello friend....anyone knoe how can i make this project
msp430 panel meter
Hi
You can do it, you will need a micro with LCD interface an A/D converter and an accurate refrance volatge source
MSP430 have it all in on single chip like MSP430F435
All the best
BOBI
microcontroller based digital energy meter
I've built this kit as a general purpose 6 digit LED display, 2 A/D 0-5V inputs could be made as a dual 3 digit display. Easy to make as a frequency counter too.
Dragonfly
how can i make digital pannel
exactly what????????
freq counter...
voltmeter....
etc etc etc
design prepaid energy meter
It's got a microcontroller, a PIC16F886 or you can upgrade it and use a 18F2525. The 18F2525 has a TMR0 with enable / disable which would make it better suited for a frequency counter.
It's got two 10bit A/D inputs on the USER connector and with a simple resistor divider you could easily make it a dual display panel meter.
Yahtzee game, dice, clock, timer etc... Yep it's programmable and even has RS485
IT all depends on what you want to make and what volatge you want to read and how you want to display it.
You can have and LCD or 8 x 7 segememnt LEDS
just use an op-amp to devide the voltage say you want 0- 30 volts then use op-amp to devide it to 0- 5V. then send the data out
If you used a GLCD then you can have upto 8 channels
or use a max7219 seven segment driver
here is a link for one
https://www.electronics-lab.com/projects/test/022/index.html
wizpic
Both AVRs and PICs have some demo design on energy meters.
pannel meter
chk ic stpm01 by ST it will do all for u all u do is to get data in spi mode to microcontroller
How much is this stpm01 chip?
i think u will get the price form ST site..
