MicroC compiler help: microRTOS
bukhari917
Member level 1
Member level 1
Pakistan
hello everyone!
i'm trying to run the code given in this **broken link removed**.
static unsigned int i=0;
InitTask(1,1);
while(1)
while(PORTB.F1);
flag=0;
//Start flashing
void Task2(void)
InitTask(2,1);
while(1)
while(PORTB.F2);
flag=1;
and getting this error:
99 324 "Undeclared identifier 'flag' in expression test.c"
i'm using MicroC as discussed in paper, and trying it for PIC18F2685
this "flag" is not declared in the code, then whats wrong m i doing?
thnx for your time
You yourself say that flag is not declared, that itself is the problem...declare the variable first
as i have just mentioned, its not my code, i'm copying the code from the above given link, so he has not declared flag...and i don't know what register's bit should be named as flag, or how to declare it :-:)-:)-(
After seeing the above snippet it seems flag is a independent variable...Try to declare it and check.
hello everyone!
InitTask(1,1);
while(1)
while(PORTB.F1);
flag=0;
//Start flashing
void Task2(void)
InitTask(2,1);
while(1)
while(PORTB.F2);
flag=1;
thnx for your time
hii i'm newbie here.. could u please post here all the code from the article and say how u solve that flag problem?
