I assumed that the OP has no Sony TV in the same, or nearby room already. But would have been a good idea to check, admittedly.What happen if someone else use his TV remote and start playing with yours fans?
#define fan RC0_bit
#define lamp1 RC1_bit
#define lamp2 RC2_bit
sbit ir_rx at RA2_bit; // IR receiver 40KHz
sbit ir_in_direction at TRISA2_bit; // Infrared receiver input
// function prototypes
void get_mark_time(void); // get Sony IR mark time
// global variables
char counter = 0;
char shadow = 0;
char bitcount;
char ir_address;
char ir_command;
int mark_time;
int fan_mask;
unsigned int num,Cnt_T1;
void interrupt()
while(TMR0IF_bit)// TMR0 interrupt sub routine
counter++; // increment counter
TMR0IF_bit = 0; // Clear Timer0 overflow interrupt flag
break;
while(TMR1IF_bit)
TMR1IF_bit = 0;
TMR1H = 0xFE;
TMR1L = 0xE9; // 1ms count
RAIE_bit = 0;//disable IOC interrupt
if(!fan_mask)
// code
Cnt_T1++;
T0IE_bit = 0; // Timer0 interrupt ebable
while(Cnt_T1 >= 0 && Cnt_T1 < num)
fan = 1;
break;
while(Cnt_T1 >= num && Cnt_T1 <= 28)
fan = 0;
break;
while(Cnt_T1>28)
fan = 1;
TMR1IE_bit = 0; // disable timer1 interrupt
RAIE_bit = 1;//Enable IOC interrupt
T0IE_bit = 1; // Timer0 interrupt ebable
break;
else
fan = 1;
break;
while(RAIF_bit)// IOC subroutine
RAIF_bit = 0;// clear IOC_Flag
TMR1IE_bit = 1; // enable timer1 interrupt
Cnt_T1 = 0;
break;
}// interrupt
void GetData()
ir_command = 0; // initialise to prevent false trigger
ir_address = 0; // initialise to prevent false trigger
get_mark_time(); // get Sony leader - 2.4mS Mark, 1.2mS space
if ((mark_time > 120) && (mark_time < 200)) // set the frequency limit
{ // ignore anything but 2.4mS mark
for(bitcount = 0 ; bitcount < 7 ; bitcount++)
{ // 7 bit command
get_mark_time(); // get a Sony IR bit
ir_command >>= 1; // shift
ir_command &= 0x7f; // top bit zero
if (mark_time > 0x40)
{ // > 40 is assumed to be a 1
ir_command ^= 0x80; // top bit 1
ir_command >>= 1; // shift 1 unused bit
ir_command &= 0x7F; // clear top bit
for(bitcount = 0 ; bitcount < 5 ; bitcount++)
{ // 5 bit address
ir_address >>= 1; // shift
ir_address &= 0x7f; // top bit zero
ir_address ^= 0x80; // top bit 1
ir_address >>= 3; // shift 3 unused bits
ir_address &= 0x1F; // clear top 3 bits
}// GetData
void main()
TRISA = 0b00000111;
TRISC = 0x00;
PORTC = 0x00;
ANSEL = 0x00;
CMCON = 0x07;
OPTION_REG = 0x03; // TMR0 prescaler set to 1:16
// start timer 0 counting
GIE_bit = 1; // Global interrupt enable
ir_in_direction = 1;// set IR dirrecting
IOCA1_bit = 1; // Enable IOC at RA2
RAIE_bit = 1; // Enable IOC interrupt
RAIF_bit = 0; // Clear RAIF bit
// Timer1 settings
T1CON = 0x01;
TMR1IF_bit = 0;
TMR1H = 0xFE;
TMR1L = 0xE9; // 1ms count // 1ms count
TMR1IE_bit = 1;
PEIE_bit = 1;
Delay_ms(500);
while(1)
GetData();
num = EEPROM_Read(5);
Delay_ms(20);
if(ir_address == 1)
{ // TV
if(ir_command == 0)
{ // button 1
num = 24;
fan_mask=0;
if(ir_command == 1)
{ // button 2
num = 22;
fan_mask=0;
if(ir_command == 2)
{ // button 3
//shadow ^= 0x10; // toggle output 4
num = 20;
fan_mask=0;
if(ir_command == 3)
{ // button 3
num = 18;
fan_mask=0;
if(ir_command == 4)
{ // button 3
num = 15;
fan_mask=0;
if(ir_command == 5)
{ // button 3
num = 12;
fan_mask=0;
if(ir_command == 6)
{ // button 3
num = 9;
fan_mask=0;
if(ir_command == 7)
{ // button 3
num = 4;
fan_mask=0;
if(ir_command == 8)
{ // button 3
num = 0;
fan_mask=0;
if(ir_command == 9)
{ // button 0
//shadow = 0x00; // all outputs off
fan_mask=1;
num = 0;
EEPROM_Write(5,num);
Delay_ms(200);
Delay_ms(100);
// get time of mark, then ignore space
while(ir_rx); // wait for a mark
counter=0;
TMR0 = 0;
while(!ir_rx); // wait for space
mark_time = (counter << 8) + TMR0; // collect integer mark time
Dear All,
How should we detect the start bit using Timer0 in assembly language with pic16f877a
Thanks in advance
you can try...
