mentor graphics pcb tools
elec-eng
Full Member level 5
veribest pcb tool
What is the difference between different mentor pcb tools
pads
expedition
also our company has a choise to buy pads or expedition or Altium designer
So which to buy
thanks
mentor neutral cadence allegro
Pads is not bad but quite difficult to work with, Altium looks the same. However for FPGA design Altium have powerful libraries and firmware editor.
Pads have some nice readable documetation (splitted in three: capture, router and layout), Altium has some very splitted documentation more difficult to read.
Who is the best ? I can't say one or the other, but evaluating Altium looks the same difficult like Pads.
allegro pads comparison
expedition is the high end tool for high speed design, difficult to learn but powerfull. auto active technology is very good for dynamic hand routing
complex pcb maintenance
Expedition isn't that hard to learn, but then again I used BoardStation before I moved to Expedition :)
mentor pads layout modeless commands
Among the Pcb design tools available from Mentor Graphics,i feel Pads layout is easier though i haven't used other software in first place,its an views & comments from my folks who have worked on them.
Expedition and Board station are used for high end designs(high speed),both are competitive to allegro(Cadence),for eg,constraint setting etc....
It may vary from individual,and again depends upon the usage of the tool extensively.
Regards
Ramesh
pcb tools,pads
so please can any one give a comparison between Mentor Expedition and Cadence Allegro
i know that they are both very powerfull
but i am confused which to use
which is more easy to learn and which is more efficient
mentor graphics
Both expedition and allegro creates a quality board and the designer makes it happen.
Well,its you to decide on the tool,when your using any tool extensively you shall be comfortable working on that tool.
Regards
Ramesh
power pcb modeless commands
It depends on what you want to design,
- normal analog or digital design using std parts (leaded or smd) involving a few layers (<6).
- complex design using fine-pitch ic's involving several hundreds Mhz (or more) and several critical layers (signals and power planes).
For the former, I use Protel (99SE & DXP) all the way -very easy and fast turn-out.
For the latter, Expedition beats Protel in ease of routing and get you out of trouble most of the time.
Of course, it is hard to learn MG Expediton initially but it pays off in due time.
I think this is the same case in Allegro too.
mentor graphics veribest 99
Pads is one Cad tool that one can easily learn....A self contained system with all kinds of cool functions and process simulations. Pads_Logic as one, (schematic capture) wherein one can create all the necessary logic symbols which you can then input the required geometry and part no. for such devices. Pads_Pcb, where you then create the geometry footprints for the symbols you have on your schematic diagram and all its attributes (part). Having all these made, you can sync both of these files either from the Logic diagram or from the Pcb Layout. This alone is the best part of these platform. Both modules have modeless commands under your finger tips just by using single button keys and number keys. One can set templates for sarting his or her design regarding layer counts, that can be opened when the decision comes stored somewhere in a Data Base directory.Pads is not that hard to learn, in fact I found it a very easy tool to learn...I know there are other neat things about Pads like, hyperlynx and DFT Audit for board testibility but, this will make it too long. I think it is one reason why Mentor Graphics acquired this package.
In the meantime, Mentor Board Station adoted another tool from it and that is where Expedition came about. A little bit smaller package than that of the board station platform but as powerful as the former. If one have knowledge of the first platform, the next one is not that hard to learn. Both have different command menu syntax, but does the same functions. Expedition can be sold by itself or as part of the Board Station platform. This platform is for high end designs and for large companies with tons of work and can afford to spend maintenance cost....
This of course are vague description of these platforms from one that uses them all the time. But again, you can take it or leave it....:|
mentor graphic product bad quality
I am doing the second MG Expedition 2005 training course now, it is very powerful ...
The trainer says that Expedition is a native MG product while Pads was just bought by MG and MG is now rewriting Pads, so I guess Expedition is more professional - although I never used Pads :D.
mentor and cadence pcb comparison
four years ago, I have trained for Mentor Expedition WG 2000.5, at that time it was also very power full tool for high end designs, however. to manage design capture is still a chalenge with me.
It's very impression with Autoactive technology. and now with WG 2005.5 SP1. it's become more native with the designer.
I also trained for Allegro, but i still like WG
have a nice day
pcb tools danish
I had used PADS and Expedition.Expedition is much more powerful than PADS.
mentor graphics pcb
I hate to disapoint you but Expedition PCB is not a native MG product (wich one is anyway?).
Expedition used to be known as Veribest Destination PCB. in 1999 Mentor took over Veribest in orderto re-establish its position in the pcb market.
learn mentor graphics
Having used all three PCB tools here is my opinion:
Expedition = Allegro
Expedition, Allegro > PADS
If you are doing high-speed, lots of diff pair routing or HDI you need to go with Allegro or Expedition. PADS is not stable enough when boards get really challenging. That being said, if you are doing simple designs, PADS is the best bang for your buck.
Expedition and Allegro are quite similar in their capabilities and it really depends on which flow you prefer or already have experience in.
Other points to take into consideration:
- Mentor technical support is better than Cadence technical support.
- In our experience Mentor Sales will do much more for you than Cadence (we've found Cadence to be a very arrogant company in the past 5 years).
mentor graphics cost pcb
“we've found Cadence to be a very arrogant company in the past 5 years.”
It's true.
mentor graphics to allegro
It's true. "
I too feel the same.
I am a cadence costumer for the past 3 years, and a member of cadence users & forum. None of the tech support contacted me all these days and not received any updated mails, not invited for the user conferences which is held in my city.:cry:
But recently I happened to visit MG website, soon I got a call from a local tech support, and later I could attend the U2U conference, which helped me to know their products. Now, I feel an attachment with MG tools, eventhough I am not familiar with it. :D
regards,
rinj
mentor graphics pcb pads price
At this time the support of Mentor are very best, for all aspect. Expedition, are high-end tool, but Not so ease to use.
For my experience, PADS > Altium for pcb and routing. The DX designer are now updated, not easy but good, need some updates for increase the ease of use.
If Mentor expand PADS for large and critical boards (only one step < expedition), for Reliability, support for Linux platform, and (Important) include a SI Simulator in PADS basic bundles. PADS go to the best ease and powerful system for all need, at low cost, Without competitors !
Remember in the past PADS was competitor of high-end tools.
Skywalker.
mentor wg expedition pcb
forget altium
is pads pcb hard to learn
Quality board if qualified personell are using those, else... big sh*t.
