Mentor ADVance MS simulator
lovanca
Newbie level 6
Newbie level 6
Hello,
I am currently using ADvance MS to simulate some VHDL-AMS models.
I would like to output some results in an ASCII file. I can do it in the ADvance MS graphical environnement using the Nets window then view>List>Selected nets.
But I would like to be able to do it also in batch mode :
Therefore I wrote a .do file
# Elaboration phase
if [ batch_mode ] {
add log :order3:dut:*
add list :order3:dut:*
} else {
view structure
view nets
add wave :order3:dut:*
# Simulation phase
run -all
# End of Simulation
if [ batch_mode ] {
write list output.lst
quit
and launch the simulation. Each time I get the same error message :
ADMS> # Error: Internal Error
# Occurred in DUT(CT_IDEAL/ADC_SD_1BIT) at time 0 fs
# #E Error in tcl script file adc_sd_ct.do: No object found matching :order3:dut:*
But when I use the .do file without the add list command line, It runs and I do not get any trouble.
Any idea on how I could do ?
Lovanca
How can get DVance MS evaluation.
I am form Iran.
and mentor garphic dos not gine me link for download.
pleas me link for download ?
At the moment I'm working on some vhdl-ams models for multiplexed input sigma-delta adc for simuation, but at the very beging I run on problems with ADVance MS simulator under Mentor Graphics.
So does anyone have expireience with ADVance MS, VHDL-AMS simulator?
I'm using vasim version v4.6_1.1, and when I trie to compile any soure vhdl-ams script (using command: vacom <scrpt_name>.vhd), compalation fails and I get this error:
"gcc installtation error cannot execute 'cc1': No such file or directory".
I dwonloaded latest version of gcc compiler, bat I still get the same error.
If someone run in the similar problem please post solution.
Thanks in advcance.
Hello again,
after some mentor support net exploring, I found solution for mentioned problem about ADVance MS vhdl ams simulator under mentor design kit, so i find it would be useful to share it with you guys. I hope that it will help someone who run on to same problem as I did, so the solution:
Everything that is need to be done is to unset the following system variable in your unix/linux shell/bash script located in your home directory. Simply type
unsetenv GCC_EXEC_PREFIX
Note: of course you need to source shell script after this change.
Basically versions of ADVance MS after 2007 do not relay on gcc compiler any more.
LaTeX Commands Quick-Menu:
