rowan.bradley
Junior Member level 1
I work on a system based on the 8051-family 80C320 processor. It has a 16 address bit 8 data bit bus, plus read/write etc. The IO is all memory mapped. I now want to replace or augment the processor with a new modern processor (an ARM or similar). I still need to use the existing memory mapped peripherals. Ideally I would buy a modern processor board (giving me USB, Ethernet, lots of memory, C compilers, a modern operating system maybe Linux, and if necessary video and sound output, keyboard and mouse input etc.) and interface it to the existing 8051 bus so I can still write to and read from the peripheral registers. Is this possible? What is the best way of designing it? Are some microcontrollers better than others at handling this type of IO? What sort of adapter circuitry would I need to connect the new micro to the old bus? Of course the new processor will be much faster than the old (which runs at 12MHz). I would rather use an off the shelf processor board for the new processor than design it from chips, since that should save a lot of work, and give me a working starting point.
Ideally I would like to be able to read and write to peripheral addresses using a single instruction in the new processor. This (I think) rules out using GPIO pins for the address and data bus, because this would involve a lot of instructions just to do one read or write cycle.
Thanks - Rowan
Thanks - Rowan
