pejdstran
Newbie level 3
virtex 4 mini module
Hi everyone!
We recently bought a Memecs Virtex-4FX12 Mini-Module development kit. It seems like an ideal FPGA based System-on-a-Module (low price, very small, high performance, DDR-RAM and FLASH on-board...). I encountered severe problems at JTAG programming - in most cases programming fails, because done bit is not 1. IMPACT, when run from XPS outputs this message:
WARNING:iMPACT:2218 - Error shows in the status register, release done bit is
NOT 1.
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0011 0000 0001 1000 0000 0000 0000 0000
INFO:iMPACT:579 - '2': Completed downloading bit file to device.
INFO:iMPACT:580 - '2':Checking done pin ....done.
'2': Programming terminated, Done did not go high.
Elapsed time = 36 sec.
make: *** [download] Error 1
Done.
I tried programming with Avnets Spartan3 starter kit JTAG cable and ALTIUM JTAG cable (both probably paralell cable 3) using only supplied reference designs. The problems are the same with both cables.
Q: Does anyone has Memecs V4MM? If yes, what cable is he using? Is anybody familiar with such problems and what might be the solution?
THNX
Guru
Hi everyone!
NOT 1.
Done.
THNX
Guru
