oiyela
Junior Member level 3
Hi, i am currently doing a project on speech recognition using a neural network. i have recorded all my sound sample and extracted it as a wav file. i have been able to read the wav file and display it on a time-domain graph and also a spectrogram.
i need to know convert the speech signal into mel frequency cepstrum coefficients, having difficulties understanding how to do this.
i found out this fuction
MFCC(S,FS,TW,TS,ALPHA,WINDOW,R,M,N,L)
S is the input speech signal (as vector)
% FS is the sampling frequency (Hz)
% TW is the analysis frame duration (ms)
% TS is the analysis frame shift (ms)
% ALPHA is the preemphasis coefficient
% WINDOW is a analysis window function handle
% R is the frequency range (Hz) for filterbank analysis
% M is the number of filterbank channels
% N is the number of cepstral coefficients
% (including the 0th coefficient)
I do not know what values to put in for TW,TS,ALPHA,WINDOW,R,M,N,L
Please help if you can thanks
