mega16l usart max 232 with vcc=3.3v
khatarat
mega16l usart vcc=3.3v
hi
i want to create a circuit that have an atmega16l to send some information via usart using max232.
my circuit work when i use 5v as supply power but not when i use 3.3v
i use 6 mh ocilator
what should i do. is there a specific work should be don with lower voltage than 5v like 3.3v?
This is because the MAX232 doesn't work below 4.5v.
focus.ti.com/lit/ds/symlink/max232.pdf
Hope this helped.
Tahmid.
Re: mega16l usart vcc=3.3v
it means that input should be more than 4.5v or suppluy power should be more than 4.5v?
You can power the ATmega with 3.3v, but the MAX232 must be given a supply power voltage with at least 4.5v, most suitably 5v.
For 3.3v operation, you can use a boost chip, like LT1073 or something like this.
Hope you got it.
Tahmid.
i have tested max232 with 3.3v its worked well
can i chat with u(google talk or yahoo messenger?)
I don't use IM.
According to datasheet, MAX232 is not to work at 3.3v.
I don't think there's a problem with code as it works at 5v.
Tahmid.
recomended voltag is 5v but it work with lower powers
i think that problem is from output of micro
when i use 5v out put is about 5 and circiut work well but when i use 3.3v output is abut 2v and max232 cannot get it
I think that's why 5v is stated in datasheet.
Why do you need 3.3v, will it not do with 5v?
Tahmid.
Hi khatarat,
You may use MAX3232 designed to operate at 3.3V. The min input high requirement is 2V, which is available in your case.
